Business Welcome Logo
Hey guys!! I was wondering if anyone could be able to help out with the attached file. I've tried cutting it out multiple times and the wrong pieces are falling out to make it look right. Any help would be greatly appreciated.
Re: Business Welcome Logo
On a quick glance, your svg has the original artwork way out on each side of your design you want making the svg huge. I would delete those. On your truck, there is alot of crossing lines on the door and the front of the truck box. Probably due to ends of lines not closed. Hope this helps.
Ok thank you
I'm not sure what sbest is talking about with the original artwork, as all i see in Inkscape is the truck in the circle, but he/she is right about lines. they are too close together which is why it will blow part of your drawing out in many places. And you have cuts inside of cuts, like in the cow head on the door. You need to open up and manually alter nodes, moving them so they are not so close together. You may even want to just do away with the garbled letters on the door.
There are 2 other drawing pieces in the SVG. Way to the left of the truck is one and way to the right is another - altogether they make the whole thing about 1275 inches wideliv2speed05 wrote: ↑Sun Feb 17, 2019 9:12 pm I'm not sure what sbest is talking about with the original artwork, as all i see in Inkscape is the truck in the circle,
You can see them if you zoom to fit the drawing and then do a Ctrl-A to select all. You'll see the two edge drawings at really tiny scale. If you ungroup and then move the two side drawings out you'll find one is this Welcome circle. One has a barn & tractor scene and one has the whole SLS logo. Looks like either alternate versions of the sign or buildups someone was working on - all saved in the same file though. But at 100 feet long by 4 feet tall, it's likely to choke something like Sheetcam.
I agree on cleaning up the lines and lettering (and some other detail) on the truck.
Oh OK. I see what you are talking about. LOLjamesdhatch wrote: ↑Mon Feb 18, 2019 12:07 am There are 2 other drawing pieces in the SVG. Way to the left of the truck is one and way to the right is another - altogether they make the whole thing about 1275 inches wide
