A couple from today
A couple from today
Once I cut them I will Share
Mick
Owner/ operator
MJT rural Contracting
Weldclass t1200
Hypertherm Pwermax 45XP
Owner/ operator
Weldclass t1200
Re: A couple from today
Post pics once your have them cut they look great!
Just a quick test of the shark. These are a couple of Rugby League teams here in Australia
Mick
Owner/ operator
Weldclass t1200
Owner/ operator
Weldclass t1200
It's coming along. What cut speed and cut height are you using?
1.5mm height and 85mm/ sec.
Mick
Owner/ operator
Weldclass t1200
Owner/ operator
Weldclass t1200
Looking good but you can likely improve that edge quality a lot. I suspect your motion isn't smooth or your THC is oscillating up and down slightly. If you do a similar cut with the THC off does your cut edge smooth out?
I was thinking the same thing - that is why I posted the close-up photo showing those wavy edges.plasmanewbie wrote: ↑Fri Sep 24, 2021 9:56 am Looking good but you can likely improve that edge quality a lot. I suspect your motion isn't smooth or your THC is oscillating up and down slightly. If you do a similar cut with the THC off does your cut edge smooth out?
I'll try that thanks fellas
Mick
Owner/ operator
Weldclass t1200
Owner/ operator
Weldclass t1200
Please keep us posted on any improvements in your cut quality as you experiment with your hardware and settings.
Okay so I swapped the torch mounting plate around and it seems that have been the issue. I will do some cutting tomorrow and get pics. I did run the shark again and it came out better. I've also slowed the feed a touch
Mick
Owner/ operator
Weldclass t1200
Owner/ operator
Weldclass t1200
That's good to hear! I will look forward to seeing your results.
Another thing you could try is attaching a ink pen to your torch to see if your moving section needs a tune up. The fine tip on the pen will show more detail. Paper is cheaper than metal.
https://www.youtube.com/watch?v=Tet2rRsqBts
Great idea Tom! Another good use for a 3D printer. Lots of fun to be had here!acourtjester wrote: ↑Sat Sep 25, 2021 9:47 am Another thing you could try is attaching a ink pen to your torch to see if your moving section needs a tune up. The fine tip on the pen will show more detail. Paper is cheaper than metal.
These are the results
Mick
Owner/ operator
Weldclass t1200
Owner/ operator
Weldclass t1200
Nice work it great when you can find how to correct a problem, more knowledge of the working of your table.
Thanks David here is a newer version being used by TJ to check a file before cutting.
https://drive.google.com/file/d/1MQ2Oyu ... sp=sharing
That edge does look better.
Tom - thanks for sharing that! That is a nice design using the spring to apply pressure to the pen. Much better than mine that depends on gravity to keep the tip of the sharpie in contact with the paper.acourtjester wrote: ↑Sat Sep 25, 2021 8:48 pm Nice work it great when you can find how to correct a problem, more knowledge of the working of your table.
Thanks I use the same design for a metal scribe to mark metal, it is a little more sturdy for marking with a diamond tip.
https://drive.google.com/file/d/14hig0J ... sp=sharing
newer design to mount directly on the torch.
- ETCWeld
Are you selling these? I tried using a sharpie taped to my torch head once.acourtjester wrote: ↑Sun Sep 26, 2021 9:51 am Thanks I use the same design for a metal scribe to mark metal, it is a little more sturdy for marking with a diamond tip.
I was trying to make a bumper for a 1st gen tachoma from a later model dxf. I tried cardboard (giant fail) and then hardboard panel (.175x 4x8) so I could see what i needed to change to make it fit my truck. It didn't make it thru the first pattern.
sure will I will send you a PM from here with details today.
- ETCWeld
Received and replied to. Thanks!!
I made a few more adjustments to the z axis and was happy in 2mm so I stepped up to 5mm.
Mick
Owner/ operator
Weldclass t1200
Owner/ operator
Weldclass t1200
Those edges look greatly improved.
Yes very happy. Just waiting on my air dryer now
Mick
Owner/ operator
Weldclass t1200
Owner/ operator
Weldclass t1200
