2 - Bird (Wren) Welcome Signs
- tony506
Hope someone can use them.
Eastern Canada
Hobby Shop/Business
PlasmaCam DHC2 with Design Edge
Hypertherm Powermax 65
Lincoln Mig
Everlast Tig & Stick
Hobby Shop/Business
Lincoln Mig
- WyoGreen
Re: 2 - Bird (Wren) Welcome Signs
Nice, thanks for the file.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
Nice...your "e"s will fall out though.
Precision Plama LLC SDB 5x10
CandCNC
Hypertherm 65
Mach3
SheetCAM
the GIMP
inkscape
QCAD
https://www.facebook.com/burtonskustom
CandCNC
Hypertherm 65
Mach3
SheetCAM
the GIMP
inkscape
QCAD
- tony506
Thanks Bogger,
I found that out when I cut it yesterday....
I'm still learning....)
Eastern Canada
Hobby Shop/Business
Lincoln Mig
Hobby Shop/Business
Lincoln Mig
thanks for sharing
Thanks for the share
nice files ..and you never stop learning ....thanks for sharing
Very nice, thank you for the post.
- david jordan
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Thanks for sharing!
Very Good---Thank You for sharing!
LDR 4x8 Water Table
Hypertherm 65 Machine Torch
Sheet Cam
Mach 3
Sheet Cam
Mach 3
- kchoghead
thanks for the share
Nice. Thankyou
LDR 4x8 Water Table
Sheet Cam
Mach 3
Sheet Cam
Mach 3
Great share Thanks
