Does anyone have wheel bolt patterns
Peechy
Post by Peechy »
This is what I'm looking for . Apparently these are good for putting on rims to remove cars from fields . after being welded on rims they will fit any bolt pattern . If anyone has this to share that would b great !!
8-)
Shane Warnick
Re: Does anyone have wheel bolt patterns
Post by Shane Warnick »
My software will make flanges, ie bolt patterns. Just need to know ID, OD, the diameter of the holes and the cirlce the holes are on and how many (ie 5 holes on a 4 1/2" circle, 7/8" holes) with whatever ID and OD you want. PM or post it up here which ones you want and I will frankenstein them all together.
Shane
Pulled this from Google don't know if its correct but looks like 3 patterns.
wheel bolt patterns.dxf
agteacher
Post by agteacher »
I have one of those but it is plastic. The only thing I knew they were for would be to find the correct pattern on a 5 lug vehicle/wheel. I don't think I would trust this to be welded in a wheel and drive it on a car.
Down here where I am they sale them at the trailer supply stores, a paper version for $1.00 so you can figure what kind of rims to put on your hubs.
Randy Dobbins
Welding Teacher Humble ISD
Peechy
Post by Peechy »
Yeah probably a good scan on the computer would dooo . But mines plastic not paper doesn't read it right .. :twisted:
8-)
Binderman
Post by Binderman »
I could so use this just as the OP stated. Its only temporary for getting vehicle/equipment on a trailer and getting home. We have a couple of double pattern wheels that we use regularly for retrieving cars and trailers and such.
If anyone can make one up you will be my hero!!!
Subscribed!!!
pertneer
Post by pertneer »
Here is one I created, but I had never cut it. It is only for 5 bolt patterns at 5.5, 4.5, 4.75, and 4.0. I know the 5.5 and 4.5 work on most trucks, not sure about the others.
boltHoleGuide.DXF
boltHoleGuide.zip
This is the solidworks model if interested.
4'x8' CNC Plasma w/Water Table Running a Powermax 65 :D
CandCNC, Mach3, SheetCam, Millwrite Plasma V6
KKesner
Post by KKesner »
Thanks for the share pertneer, I've had a need for one these from time to time but just never bought one. I'll cut one and give it a try.
"Only two defining forces have ever offered to die for you; Jesus Christ and the American G. I. One died for your soul; the other for your freedom."
HammerDownJustin
Post by HammerDownJustin »
I do alot of wheel centers for mud trucks and rock crawlers..if you know what patterns you need just holler
Miller 251 Mig
cncdaver
Post by cncdaver »
looking for 2.5 ton military big 6 lug wheel pattern and 1 ton old dana 70 8 lug wheel pattern if anyone has either of them I would love to get them.
Thank you very much !!
