Personalized Deck Lantern
ISUWIZ
Post by ISUWIZ »
Hello everyone! I am relieved to be done with my latest project with a day to spare so I have some time to share it with all of you!
A good college friend of mine is getting married, has an eye for unique graphic art (Design Major). I really had no intention of making a plasma-cut gift for her and her fiancé, but after being inspired by fellow member Russ K's awesome ocean-themed deck lantern, I knew I had to try and make something that they could cherish forever as a reminder of their love and the Light in Christ that they will represent together every day from this Saturday forward. Russ was very gracious to help me with a few questions I had about the build, and I will try to explain my process as well! (here is the link to Russ' Lantern) http://plasmaspider.com/viewtopic.php?f ... rn#p112458
Design Phase:
The shape of the deck lantern is a truncated octahedron, which has 8 hexagonal sides, and 6 square sides - 14 in total. This meant that minus the base, I would have 13 "tiles" to play with and try and come up with something meaningful to the couple. Solidworks is my primary design tool, and throughout this project I have learned a few tricks of the trade as far as text, importing and "cleaning up" dxf files, and even creating my own designs. I guess the easiest way for me to explain will be for me to go through each tile.
SQ1: Emily
SQ2: David
SQ3: 2017 - their wedding year
HEX1: I knew I wanted to do a split-monogram of their new last name for the front-and-center hexagonal tile - purchased all 26 letters from Etsy for $2.99, but this file required an ENTIRE re-draw via Solidworks to reduce nodes and noise, as well as thicken some of the curves to they wouldn't burn through during the plasma process.
HEX2: David comes from a Christian missionary family, and was born and spent his early childhood years in Egypt, and they both have been avid world travelers, so I found this very unique family tree/world map image I believe on Etsy. If I remember right, it was $2.99. Generally the file was pretty good, but for me to cut out the image in a hexagon with 6 1/4" , I spent an hour or so editing, re-tracing parts, and tying dropouts together in Solidworks.
SQ4: Matthew 5:13 (notice the location above "the earth")
HEX3: Often used bible passage from 1st Corinthians says 3 things remain -- in addition, the triangle - representing the tri-union God in the center of their life.
The rest of the tiles represent something about the couple individually, according to the side the tile is on, it means something about that person
HEX4: Gardening/Succulent Plant - Emily drew a sketch of one of her succulent plants and sent it to me a couple years ago in a design portfolio, and so I took the liberty of scanning the image, completely tracing/re-drawing in Solidworks, and then attemping to add as much of the original detail as possible with open profile cuts.
SQ5: Photography - Emily (and also David) are avid photographers
HEX5: Artist's Palette/Computer - Emily was a graphic design major, and works as a graphic designer at a major Christian university.
HEX6: Hiking - David is an avid hiker and adventurer
SQ6: Coffee - David is what one would call a "coffee connoisseur" - this one was a google-search gem, that I ended up completely re-tracing
HEX7: Bridge/TowerCrane/Road - David is a civil engineer - two Etsy images, completely re-traced and added together in solidworks.
So in short, I modeled the lantern completely in Solidworks, including the lamp post topper and globe I was going to use on the inside. I decided on a 14" globe and a little larger design than Russ' lantern, because I needed a little extra room in my tiles for some of the detail I wanted to include. Heres an older screenshot I can find right off hand..
Build Phase:
Using all scrap pieces of 11GA and 7GA A36 left over at work, I starting cutting tiles. A few a day for a couple days in a row over my lunch hour. We have a Hypertherm 400XD machine on a Koike Aronson water table with Hypertherm THC. The 7GA (the base) cuts beautifully on the 80A process. In general this machine doesn't seem very good at cutting thinner material, but it does okay. I used the 50A process on the 11GA with the machine's programmed base ipm of about 60, but I think this is a little slow. Pretty much everything cut out well and only had a minor blowout on the succulent plant, but went with it anyway. The cutting time overall was about 52 minutes.
Before tacking any of the pieces together, I made "angle finders" for the different angles that the legs and tiles get welded on at. 120deg for the legs, 109.47deg for the hexagons, and 125.26deg for the squares. This nearly took all of the "tack and tweak" out of the build process and by my estimation saved a LOT of time. Once I got the majority of the tiles tacked on, I double checked that my globe was going to fit. It clears by about 1/4" or so on two of the sides, which is just perfect. I used a stainless steel piano hinge I had left over from another project to attach the "door" with, and then actually tacked the door to the rest of the lantern so it would not move or deform as I welded all of the other seams. Once welded, I used a flapper wheel to grind down the seam welds on the door and lantern, and then cut the tack welds where the door meets the rest of the lantern. Considering its my first time, I think the door fits great!
Next I added two little tabs on the door and lantern base so that a padlock could be used to keep the door from opening when picking it up. After that, I used a cabinet blaster to sandblast the metal to a rough finish to promote powdercoat adhesion. The powdercoat I used was an outdoor grade copper vein, and I'm very satisfied with it. Wiring the lamp post topper was pretty straightforward. Tapped a machine screw hole to attach the ground wire to, and a nice cord and heat-shrink took it from there!
Sorry about the small novel I just wrote!! While this took me way more time than I would like to admit, this is by far the neatest thing I have built, and I wanted to share with everyone! Comments and questions are always welcomed!
Now lets see if I can get some pictures and a few dxfs posted. Might have to do it in multiple posts.
ISUWIZ
Re: Personalized Deck Lantern
Post by ISUWIZ »
Attached are some of the tiles. Enjoy! If you end up using any, let us here on the forum know!
hex top.DXF
david engineering final.DXF
square side emily2.DXF
square side coffee.DXF
salt new.DXF
hex side emily succulent.DXF
hex side david.DXF
hex back center.DXF
Emily graphic design art.DXF
Post by tnbndr »
Nice project
Metal Works
Post by Metal Works »
VERY NICE THANKS FOR THE SHARE
kgc1031
Post by kgc1031 »
love them! thanks for sharing
Largemouthlou
Post by Largemouthlou »
That is VERY NICE!!!!!!!!!!!!!!! Thanks for the share as well!! Nice toy ya get to play with at work!! LOL
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
Proballz03
Post by Proballz03 »
Thanks for sharing.
PlasmaRoute "DO NOT BUY there Plasma table from this company NO Support"
Thermal Dynamics A-60
ArtCam
Sheet Cam
Mach3
Refrigerator dry Air
Charlotte,NC
https://www.facebook.com/pages/ACSD-Art ... 90?fref=ts
shinertx
Post by shinertx »
Thanks for the awesome file.
Samson 5x10
Designedge software
Hypertherm Powermax 65
Hypertherm powermax 380
Thermodynamics cut master 85
Jet 4' box & pan break
Eastwood Powder coating guns.
david jordan
Post by david jordan »
Very nice, thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
hdfaster
Post by hdfaster »
This is a great personalized gift idea. Thanks for sharing.
BanksAg
Post by BanksAg »
That's super cool. My mom might need one of those with all the grandkids for Christmas.
Tim Eggleston
Banks High School
Banks, OR
Arc Pro 4800
PowerMax 45XP
Mach 3, SheetCam
Inkscape, Rhino 3D
Russ K
Post by Russ K »
Hi ISUWIZ, Your lantern is even more personal and interesting now that I can see all the panels and hear the background on each one. That is heavy metal you used. Mine was only 11G although I must confess a preference for thicker metal. Your friends are getting a real treasure! Best wishes for happy years ahead based on a threefold cord!......Russ K
Thanks for posting, simple changes to the internal panel shapes make is very flexible for other's to fit their design/wants :D
BILLETMAN
Post by BILLETMAN »
thank you so much for this !!!
JerryC
Post by JerryC »
Thanks for the share. That is so cool
JerryC
Post by JerryC »
Do you have the file for the base. Thanks
michmetalman
Post by michmetalman »
Beautiful pieces!
East German
Post by East German »
Very nice
Regards Peter
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
ISUWIZ
Post by ISUWIZ »
Thanks for all of the kind words! If anyone needs help with a build I'm willing to share what I know! I'm including the DXF file for the base, which includes a hole for a 3" OD pipe for mounting the lamp post topper in the middle, as well as holes that allow you to loosen the screws to remove the globe from the lantern without removing the entire lamp post topper.
Also pictured is yours truly, the lantern, and the backlit Chicago Skyline I made for Emily's twin sister at the same time as this project.
Hope you enjoy, and very glad to be a part of this forum!
-Calvin Carlson
lantern legs.DXF
hex bottom.DXF
Metal teacher
Post by Metal teacher »
cool thanks
steel 35
Post by steel 35 »
Good stuff, Thanks
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
chucko907
Post by chucko907 »
Very creative and great work. Thanks for the share.
Metal Works
Very Nice wife seen it and whats one for Chrismas
AREA
Post by AREA »
Old topic but this is awesome, very well done, thanks for sharing!
Zippo
Post by Zippo »
thanks for posting...
