Rocket stove DXF design for plasma
Re: Rocket stove design
- DesertFabworks
That piece gets bent on the lines and slides in the wood shute 45 to allow an air gap and prevent fuel from blocking flow path. Not sure what an OP is but if that person is talking about me I'm active on here daily
Desert Fabworks LLC
Fort Mohave, Arizona
www.desertfabworks.com
Follow our CNC Plasma Build:
www.cncplasminfo.com
Follow our CNC Router Build:
www.cncrouterbuild.com
OP = original poster
Glad to hear you are still active. Your last post was on March 6, 2019 so we didn't know if you were/are active still or not.DesertFabworks wrote: ↑Sat Mar 05, 2022 8:59 pm That piece gets bent on the lines and slides in the wood shute 45 to allow an air gap and prevent fuel from blocking flow path. Not sure what an OP is but if that person is talking about me I'm active on here daily
"OP" stands for Original Poster. Good to hear that all is well.
search.php?author_id=7803&sr=posts
- DesertFabworks
Your data is wrong
Desert Fabworks LLC
You can click on the "Post:" xxx number below your name at the upper right hand corner of any of your posts. Try it and you can see a historical record of all of your posts. These can be new topics you started of your replies to existing threads. You have posted 3 times today, and your last previous post was in 2019.
This doesn't include threads you have viewed, only the ones you have commented (posted) in.
That's what I'm seeing also.
Perhaps he has more than one account, in which case we would need to know the user name for that account to see posts associated with it.
I see That makes Sense. Thank you very muchDesertFabworks wrote: ↑Sat Mar 05, 2022 9:00 pm That piece gets bent on the lines and slides in the wood shute 45 to allow an air gap and prevent fuel from blocking flow path. Not sure what an OP is but if that person is talking about me I'm active on here daily
- DesertFabworks
Good to hear
Thanks for responding.
Hi many thanks for dxf
Can anyone say what this piece is for thanks
Thanks anyone a pic of it finished ? On the stove
- DesertFabworks
You can see pictures of the stove here https://www.cncplasmainfo.com/dxffiles.html
Desert Fabworks LLC
Also what size is the cut on the upright 4 x 4 tube to allow the 45 to join in
- DesertFabworks
Any size you want
Desert Fabworks LLC
- tinspark
If I am understanding correctly you are asking about the tube cut..
If you are using a 4x4 tube, your cut would also be 4" in order to achieve a 45 deg. angle on a 4" tube.
A 6x6 tube would be a 6" cut etc..
You can use a tri-square to verify the notch.
If you want a different tube takeoff angle, this will not work and will need to either lay out or trigged..
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Hypertherm 45XP-
Re: Rocket stove DXF design for plasma
thank you for the share do you have and thoughts on venting the grate supports in case you use a large pan. i thought about raising the grate but like the flush fit of the cooking surface
