Re: 13 More Fire Ring Designs!!!
- Robert1999
Hey guys,
have been a little while since I've posted been super busy here at the shop. I have 13 more rings for you guys put all in one DXF.
Just so you know I make these out of 11ga steel and believe they all roll to about 30" Dia and 12" tall except for one.
Enjoy Guys,
Enjoy Guys,
5x10 FabCut CNC Plasma with a Powermax 85
Many welders MIG, TIG, Stick
lathes and mills
And Many More Toys.
Started as a hobby and nows a career.
lathes and mills
And Many More Toys.
- otisa2007
Re: Re: 13 More Fire Ring Designs!!!
nice thanks for the share
Great share, thank you! Love the tree fire ring
- ETCWeld
Thanks for the files. Have a great day
Thanks, very nice stuff, very generous of you.
- hdfaster
Nice collection of rings, thank you!
- Robert1999
No problem everyone
lathes and mills
And Many More Toys.
lathes and mills
And Many More Toys.
I've never made a rolled fire ring, but I'd like to. Do you roll these in a roller? Is there any issue getting a "smooth" roll, once material is cut out? I'd expect them to bend easier where more material has been cut out, and be harder to bend where there's more material along the bend line.
Either way, thanks for the share!
Motoguy, Fire rings are my top seller. I built a roller years ago using 3 or 4" heavy-wall tubing, C-channel, 4 bolt flange bearings, and a gearmotor. Ill try to snap some pics. Its incredibly crude, yet very effective. you are correct about overbending where material has been removed. That may be due to the slight flex to my machine... or just the nature of the beast. I always prefer to slightly OVERbend all of my rings, and force open while welding. its easier than the alternative. I TIG fusion weld the seam for a nice unnoticeable weld. I also use an L-shaped stand roughly 4' tall that I hang the ring on wile welding. This allows me to apply more or less pressure opposite the weld to force into a nice round finished ring.
- cstroke
Overbending seems to be an issue, it's just less and more pressure by feel.
I had a fire pit crack through the weld seam after a few years of use so I now gap and get a 100% penetration weld.
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
- Robert1999
yep the big thing is to take your time with them don't try to roll all in one go I weld both sides and grind outside smooth and leave the inside bead never had one crack or break they are good sellers I sell to a lot of RV campgrounds and cottage rental places large orders between 10-100 at a time. good money in doing custom rings.
lathes and mills
And Many More Toys.
lathes and mills
And Many More Toys.
You are awesome buddy, real nice files. Thank you so much for sharing.
Greg
Greg
- Robert1999
No problem enjoiy
lathes and mills
And Many More Toys.
lathes and mills
And Many More Toys.
Thank you for the files.
The fire rings arent in the dxf when i open it, anyone else have this issue?
thanks for sharing
- Zippo
Thanks for posting...
Thanks for sharing
Haven't made any fire rings yet, but
some of these make me think I should!
