Tree of Life Windspinner 16X16
Re: Tree of Life Windspinner 16X16
Thanks for the file. I think I may cut it for the wife.
Newbie to plasma cutting.
Thanks for sharing
Hypertherm 65
Hypertherm 65
Thanks. I think it needs some tweaking to add non cut areas for the bends.
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
Miller 350P
as sphurley said there needs to be some bridge between rings to connect them, this file will cut a bunch of rings
Looks nice! What do you mount this on to make it spin?
- ETCWeld
here is an updated version that should keep the rings from falling out, haven't had a chance to cut it yet but it should work if anyone else tries it first let me know if something needs changed.
- cstroke
Looks great. I've used fishing swivels with heavy spider wire(fishing line) in the past.
Chris
Chris
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
Very nice!
Hmm. Before I uploaded it had the dividers. I never have any luck converting files. Great job.
What type of metal did you use in this picture? Does it have a finish? Beautiful work and smooth cut. Thank you for sharing.
akirk1978 wrote: ↑Sun Jul 07, 2019 6:35 am here is an updated version that should keep the rings from falling out, haven't had a chance to cut it yet but it should work if anyone else tries it first let me know if something needs changed.Tree of life curly.svgTree of life curly.dxfTree of life curly Spinner final.png
That was just a computer generated render of the .dxf file to show what it could look like, what I used to get that look was a sample image of brushed stainless steel though.MrsSavage wrote: ↑Sat Jul 20, 2019 4:37 pm What type of metal did you use in this picture? Does it have a finish? Beautiful work and smooth cut. Thank you for sharing.
Love the design! How do you bend the design for hanging?
This is awesome! I love cutting wind spinners and will most definitely do this one!
Anyone have any tips on bending one lol?
i lay em out flat in my lap and starting with the outside , just bend it uo up to about 140 degrees. Continue with remaining rings. flip it over, do other side. takes maybe 2 mins , including final spacing. easy to do , and end result is great. I have a local company laser cut spinner part and I weld in my own designs in center. makes great looking spinners
Thanks for sharing,
Peter
Peter
To bend those. Hold the top with one hand and the bottom against your stomach securely. Now use your other hand and grasp the middle section. Give it a twist and both sides will twist evenly. Takes a few seconds this way. There are also some videos online on how to do this.
awsome, what gauge do you guys use?
Works good for me in 16 Ga
Hypertherm 65
Hypertherm 65
Awsome thanks for the file. IT made a cool gift. painted it with automotive candy paint and hs clear.
