Hello all! i found these shelf brackets at some point somewhere and now i cant seem to remember where i found them. does anyone have a quick file they could link up to get something similar cut out. thanks in advance!
ButterS
looking for Shelf Brackets
Cyrious 4x8 Water Table
Hypertherm 85 Power Unit
Millermatic 252
Lincoln 140
Ellis 1800 Band Saw
Millermatic 252
Lincoln 140
Ellis 1800 Band Saw
Re: looking for Shelf Brackets
Cut a gear out, cut it in 4 equal parts and weld rectangles on each of the 4.Should be easy enough to do.
Jim
Jim
Here is a sprocket. You should be able to scale it and put whatever other designs in it.
Great thank you very much!
Millermatic 252
Lincoln 140
Ellis 1800 Band Saw
Millermatic 252
Lincoln 140
Ellis 1800 Band Saw
I drew this one hope it helps
- david jordan
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Here is one...
thanks yall! i appreciate it!
Millermatic 252
Lincoln 140
Ellis 1800 Band Saw
Millermatic 252
Lincoln 140
Ellis 1800 Band Saw
