Made this medal holder for a friend's kid. It's similar to others I've seen but it was fun learning how to use text in Fusion 360.
Medal Holder
Medal Holder
Re: Medal Holder
Cool design, I could definitely use this, thank you! When I opened it the text was missing and there were a couple extra lines here and there so I added the text back in did a couple edits and re posted the dxf below in case anyone else has a similar issue. Hope you don't mind. Thanks again!
Re: Medal Holder
Thanks PSDKevin for sharing, I actually need just the Girl running for a friends daughter that's taking track!
Was just what I was looking for!
Thanks again!
Thanks again!
Re: Medal Holder
No problem. I'm trying to learn to make the designs more clean. I guess I'm not really understanding how to make sure a design is all buttoned up and doesn't have extra lines. Have any tips?plasmanewbie wrote: ↑Tue Feb 18, 2020 11:21 am Cool design, I could definitely use this, thank you! When I opened it the text was missing and there were a couple extra lines here and there so I added the text back in did a couple edits and re posted the dxf below in case anyone else has a similar issue. Hope you don't mind. Thanks again!
XCountry.dxf
Re: Medal Holder
I don't think it is anything your doing wrong on this design, I think this was just a translation issue with the dxf from your software package to mine. Can be a common issue with dxfs. Thanks again!
Re: Medal Holder
thanks
