Jeep CJ7 frame plate DXF files
First post on Plasmaspider and hope I am putting it in the right place, I’m looking for a frame plate/stiffener for my 1977 Jeep CJ7 that I can use on my rock bouncer build. Thanks so much!
Re: Looking for CJ7 frame plate files
Welcome aboard! Here are some for the front and rear - you will need to take a measurement of your frame channel height and then scale these to fit.
Also check the hole sizes and spacing against your actual frame and edit as required.
These are in the correct proportion, just not to scale.
Re: Jeep CJ7 frame plate DXF files
Wow David, that's pretty awesome. You just have that design kicking around?
Thank you so much adbuch!
Thanks Plasmanewbie! I did these using Inkscape to auto trace, then Design Edge to edit. Did then yesterday per OP request.plasmanewbie wrote: ↑Tue Nov 22, 2022 9:37 am Wow David, that's pretty awesome. You just have that design kicking around?
Hookscustomfabrication - you are quite welcome! Let us know how these work out for you.
One thing you might consider is to add a sharpie pen holder to your torch and draw them first on paper or cardboard and then cut them out and fit check to your actual frame before cutting any metal. I don't own a Jeep, and was just going off photos I found for some on the internet.
Something like this one.
https://www.ebay.com/itm/125453656562?h ... R5jiopSUYQ
