Texas State Fracking Design
sonbakler
Post by sonbakler »
Shared a couple designs earlier that I made for a buddy with intentions of combining the 2 to make this and I think it turned out pretty good. Designed to be cut at 46" wide, if you go smaller you may need to tweak the detail in the pump.
TexasFlagState-FrackPump.dxf
TexasFlagState-FrackPump.svg
Re: Texas State Fracking Design
Nice design! I opened your file, linked/joined to eliminate intersections, smoothed to reduce the node count and scaled to your suggested size.
Here is the revised version.
Thanks for sharing your design.
TexasFlagState-FrackPump rev 1.dxf
sonbakler
Post by sonbakler »
Thanks David, my drawing skills are weak but by the end of the day I typically get done what I need. Have learned a lot here and appreciate al the help from you and others. If it is fast and easy can you share a screenshot of the errors you found? I can't find them and am curious.
Squatchemup
Post by Squatchemup »
nice!
DieselFumes
Post by DieselFumes »
Pretty cool, thanks for the design. Can modify this one and insert anything you want in place of the frack pump :Like
