hypertherm hyspeed ht2000 help!!!
Hello! There is an IHS cutter height adjustment unit. The problem is that the 8X1 and 8X2 8X3 connector on the dashboard is torn off, and the wire directly connected to the board is incorrectly fixed. With 8X2 and 8X3, I figured out with these two inductance sensors on the torch bracket, which are powered from the 8X1 connector and are 110 V black and white, and then the difficulties begin with the connection. There is no general view of the device with the documentation and pinout wires on the connectors in the box. There are 2 wires left from the air valve, which lower the arm with the sensors, noting that the valve is powered by 24 volts, red-black-green-black from a broken connector 8x1, please tell me please contacts for other wires? please tell me or take a picture of the work unit, please help! photo below
