Hi guys new to plasma, got a xp45 on my diy plasma table, just a couple of things as im tuning to get it right,
do you guys with the xp45 or higher, go by the book settings, leaving it at 45 amps, and controlling volts with THC,
and leaving pierce at 3.8 and cut at 1.5 mm book speed seems very fast for me, this is only on 3mm mild steel at the minute with 45 amp tips as this all that come with the 45,
thanks guys for any help and if you want to add tips for me that be great kev
XP 45 Settings
Re: XP 45 Settings
I've found the book settings to be very accurate.
- tinspark
Re: XP 45 Settings
Ditto on the book settings.
Also, I stay away from the knock-off consumables.
They look similar, but do not give the desired results over the long haul. IMO.
Regards,
Regards,
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Hypertherm 45XP-
Re: XP 45 Settings
thanks guys for help, yes been told about the knock-off stuff, kev
Re: XP 45 Settings
+1 for the knock off consumables being junk.
