I have a hypertherm 600 with a pac123t torch on it that hadn't run in a couple of years and finally decided to figure out why. In the main body is a spring loaded contact that touches the electrode and activates a little switch. The bolt hole that holds the wire in the end of it broke and the wire was not making connection. Hypertherm lists the head assembly as 120570.
Anybody have a source for that contactor, or am I going to need to buy the whole assembly?
i_r_
Parts for PAC123T torch
Re: Parts for PAC123T torch
Given the age it may be tough to get that however I am sure you could find some way of securely attaching the wire to whats left. That's what I would try first.
I may have to do that.
Anyone know if a PAC125 and PAC123 main body are interchangeable?
i_r_
i_r_
