PM 45 with PM65 duramax machine torch problem
I have an older PM45 (not XP) that I bought a Duramax machine torch for (same as the PM 65 machine torch). It will not fire and it seems to me I saw that a jumper was needed in the torch connecter for it to work. When I bought the torch from Hypertherm they said it will work fine. If I hook the hand torch up is fires fine with the trigger. So I hope a member here has the answer. I have just looked using the search here and google but cannot find the answer. I have used the torch on my PM65 fine.
Re: PM 45 with PM65 duramax machine torch problem
Stop the Job, problem was in the Cockpit, software not firing the torch. I had to tell it the pin for the output signal. Have no idea why it was not in there, but it is now and it works fine.
Haha, it happens. Nice easy fix
