how to draw a teardrop or petal shape
Nzniceguy
Post by Nzniceguy »
really simple question I know but in outline mode, can someone show me the method they would use to draw a teardrop shape or petal shape please. I am unsure how to correctly use the bezier curve or arc tools to do this.
thanks guys
Re: how to draw a teardrop or petal shape
Here is how I would do it, draw a circle make it a path. Then using the node tool grab the top node and pull it up to shape the teardrop or petal. And you can also use the node handles to reshape the sides if you want.
a petal (1).JPG (17.46 KiB) Viewed 2833 times
a petal (2).JPG (22.13 KiB) Viewed 2833 times
a petal (3).JPG (22.73 KiB) Viewed 2833 times
Nzniceguy
Post by Nzniceguy »
That is a way I hadnt thought of, thank you.
I like Tom's method. You could also do it using the Bezier draw tool. It works the same in either outline view or normal view.
Nzniceguy
Post by Nzniceguy »
Thank you, there sure is more than one way to skin a cat!πŸ‘πŸ™‚
Nzniceguy wrote: Tue Nov 29, 2022 7:26 am Thank you, there sure is more than one way to skin a cat!πŸ‘πŸ™‚
You are quite welcome! We are always happy to try to help.
Return to β€œInkscape”
