Etsy DXF/SVG Download
HCmillertech
Post by HCmillertech »
This is the first time I have tried this. I downloaded a file and opened it an it needs to be tweaked for sure. It is a Koozie holder I was wanting to put in the shop. It looks like it is all separate objects and I need some guidance on where to start and how to clean it up.
What file should I start with and then getting it to one object.
Attached is an image after Gcode
bryantar74
Re: Etsy DXF/SVG Download
Post by bryantar74 »
did you get it worked out?
HCmillertech
No I was out of town and just getting back to it. I was hoping someone knew how to help me.
ROKCRLER
Post by ROKCRLER »
You have a bunch of disjoined segments/nodes.
Whipped this up for you to try..
Koozie Rack.svg
(3.17 KiB) Downloaded 114 times
Koozie Rack.svg
Koozie Rack.dxf
(27 KiB) Downloaded 147 times
Koozie Rack.dxf
4x8 Dynatorch
PM85
~Mo~
ROKCRLER
Post by ROKCRLER »
40 downloads, anyone cut it yet?
4x8 Dynatorch
PM85
~Mo~
I downloaded it just to check out your work MO but never cut it, I didn't even know what it was lol! Now i know....
ROKCRLER
Post by ROKCRLER »
I had intentions of putting up the 3d rendering but had an early senior moment..
4x8 Dynatorch
PM85
~Mo~
Fastyankee
Post by Fastyankee »
Rokcreler,
How did you clean up the DFX? Did you just go in and have to join the nodes with the node editing tool,
That's only way I have been able to fix this issue I get it a lot when using DFX files form Etsy and other sources.
AJ
irondeuces@gmail.com
Pulmax
5x10 Star Lab plasma, scribe, pipe cutter
60 ton 53” press brake
JD2 tube bender
Hulk Tube bender
Slip roll 3/16th capacity
Ink Scape
Sheet Cam
Enroute6 user
Design Edge
ROKCRLER
Post by ROKCRLER »
Fastyankee wrote: Tue May 28, 2024 11:03 am Rokcreler,
I redrew it, i think i tried to join all the issues but was easier to simply redraw.
4x8 Dynatorch
PM85
~Mo~
Fastyankee
I can see that it was a very simple drawing.
AJ
Pulmax
JD2 tube bender
Hulk Tube bender
Ink Scape
Sheet Cam
Enroute6 user
Design Edge
Hatchet
Post by Hatchet »
Registered just to say thanks for the file. It cuts just fine and bends easily for those that asked.
Fastyankee wrote: Tue May 28, 2024 2:33 pm I can see that it was a very simple drawing.
I just tool a look at the original Etsy file and it's very simple and pretty quick to link/join the disjointed nodes.
If you are interested in learning how to draw this from scratch using the original posted image as a guide, here is one way to do it.
I have provided the actual svg file for this sequence, so you can follow along at each step to see what I have done. Let us know if you have any specific questions and/or comments.
Koozie holder drawing steps.svg
(194.84 KiB) Downloaded 18 times
Hatchet wrote: Thu May 30, 2024 10:02 am Registered just to say thanks for the file. It cuts just fine and bends easily for those that asked.
Nice job - I think it turned out great!
Return to “Inkscape”
