Question about degrees and angles
topkote
Post by topkote »
Is there a way in Inkscape to take a horizontal nature scene and make it into a stairwell panel so that the items in the scene itself remain vertical? I think you'd have to start from scratch. Am I correct?
weldguy
Re: Question about degrees and angles
Post by weldguy »
I don’t think that would be too difficult. If the scene has a frame or border around it already you will want to break the nodes where the frame connects to the interior scene and delete that frame. You can then draw a new frame the size and angle you need and weld the scene into that frame in Inkscape leaving the interior scene vertical.
djreiswig
Post by djreiswig »
I'm guessing you want to skew the scene so it will fill the area between 2 posts rather than just have a level edge of the top and bottom. No idea if this can be done or not.
Return to “Inkscape”
