oven burner
mmentel5
oven burner
Post by mmentel5 »
has anybody used a propane forced air heater for there heat element
mmentel5
Re: oven burner
Post by mmentel5 »
for a powder coating oven probable should of mentioned that
WyoGreen
Re: oven burner
Post by WyoGreen »
I remember there being some discussions over on the Powder365 forum on this subject. Scroll down to the ovens section and look around in there.
https://www.powder365.com/forum/index.php
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
mmentel5
Re: oven burner
Post by mmentel5 »
thank you I will take a look
Ryan
Re: oven burner
Post by Ryan »
You can use any torpedo heater with an auto on/off thermostat.
JDR Metal Art
Re: oven burner
Post by JDR Metal Art »
Yes they work. However you will be wasting huge amounts of heat because the forced air from the torpedo will constantly be pushing hot air out of the oven much faster than it can be absorbed by the parts. I have done several configurations with torpedo heaters and cut my fuel use by at least half by changing to propane burners that only draw the amount of air needed for good combustion.
https://custom-driveway-gates.com
Hypertherm 45XP
9' x 14' plasma table
mmentel5
Re: oven burner
Post by mmentel5 »
what type of burner are you using. where can I get one?
Return to “Powder Coat”
