spotty second coat
sawdust1
spotty second coat
Post by sawdust1 »
I have a question about putting on a second layer.
I sandblasted aluminum, epoxy first layer, flowed it out. Second layer is polyester clear matt for UV protection. When I applied the second layer I kept getting thin spots like I was looking at a dalmation dog.
Any thoughts?
Not obvious after cooking.
weldguy
Re: spotty second coat
Post by weldguy »
Not sure what would cause that but at least it flowed out and looked good in the end. If you find out let me know because I have had similar issues.
conradestrada
Post by conradestrada »
That is caused by a poor ground
ccoatings
Post by ccoatings »
Sounds like back ionization, I second the post about poor ground. How close is your ground rod?
sawdust1
Post by sawdust1 »
No idea actually!
jessienc
Post by jessienc »
back ionization from spraying with the gun to close, its charges little spots in the metal. i started holding the gun farther away and haven't had any issues since
weldguy
Post by weldguy »
jessienc wrote: Thu Jun 03, 2021 12:32 am back ionization from spraying with the gun to close, its charges little spots in the metal. i started holding the gun farther away and haven't had any issues since
Thanks for the tip, I will give that a try :Like :Like
:Like :Like :Like :Like :Like
ccoatings
Post by ccoatings »
The issue with BI and the gun being too close would be dependent on the equipment, and I would say that is would hold true for most low end or hobby controllers. For BI, you are most likely looking at a grounding issue on almost all cases. Check your resistance to ground, best with a megger, and go from there.
Return to “Powder Coat”
