Just a quick question regarding numbers for lines.
If any changes are made eg. If I were to put a M00 for a programme stop do I need to change all the numbers to be in order or can it be left out all together?
Want to put a stop after some cuts so that I can pull the parts out before they get covered in dross from the torch.
Cheers for the help.
Mtw fdu.
Line numbers matter when changing g-code?
Camcutcnc 4 x 4 plasma cutter with UC 100 Motion Controller
Powermax 45 with Machine Torch
Bobcad V27 and Mach 3
Proma THC
Now with Rotary Axis
Laser cross hairs
Proma THC
Laser cross hairs
Re: Changing g-code
In general - line numbers are optional, and used for reference only. I don't use them for my cnc machines to save program memory.
Line numbers are sometimes used for looping or subroutine calls - depending on controller.
Re: Changing g-code
I also use program stops between some operations for cnc machining so that he machine will pause and I can measure the OD, or in some cases release the collet and pull the material out to the desired length before the cut-off operation.
Re: Changing g-code
Thanks for the info David.
I have used the M00 with cnc milling when need to check tooling after certain ops to make they are not worn too much and if they have broken altogether.
I have used them for stopping the cutting when doing square tubing to change sides etc. I have manually changed the numbers manually when doing this...however, if it is a long program it can time consuming. Would there be a short cut for the same process when using plasma?
Thanks again for your help.
Mtw fdu.
Mtw fdu.
Proma THC
Laser cross hairs
Proma THC
Laser cross hairs
Re: Changing g-code
You could probably modify your post processor to add them in automatically. The post processor I use for my cnc machining centers puts in the option stops and program end automatically, and I manually put in any program stops I need.
Re: Changing g-code
I have used M00 when I an using a dimple g-code for center punching drill locations. After they are finished I have the M00 so I can change the nozzle or change the amps setting on the Plasma. Then the finish of the G-code is for normal cutting out of the parts. the line number help for the placement of the M00.
https://drive.google.com/file/d/1jdkwyU ... share_link
Re: Line numbers matter when changing g-code?
Thanks guys.
I just added in the M00 where I needed them witot changing the numbers and it all worked fine.
Mtw fdu.
Mtw fdu.
Proma THC
Laser cross hairs
Proma THC
Laser cross hairs
That's exactly what I do.
