Pyro1983 wrote: Tue Jan 24, 2023 9:45 pm One last quick question for now...is there a quick , easy way to dimension something in a drawing? For example, on this design, if I make it roughly 5" wide and want to put a 1/4" diameter hole (or whatever size i choose) at the top to hang it, whats the easiest way to make a 1/4" circle or ANY specific sized shape for that matter?
even possible?
Re: even possible?
Re: even possible?
Thanks for all the info. I messed around, changed it all up after figuring out the process a bit. See any issues with it?
Re: even possible?
I think this one look great. Just one place you might consider editing a bit.
Re: even possible?
I'll do that, thanks againadbuch wrote: Wed Jan 25, 2023 11:51 pm I think this one look great. Just one place you might consider editing a bit.
Re: even possible?
Happy to help as always! Let us see your finished heart when cut it.
Re: even possible?
Here it is without any finish work! It cut well! Cut out of 16 ga
Re: even possible?
That turned out great!! What sort of finish will you use?
Re: even possible?
Thanks, I'm pretty happy with it. I will probably have it powder coated. I know a guy that does smaller stuff dirt cheap. Not sure what color yet.adbuch wrote: Sat Jan 28, 2023 7:49 pm That turned out great!! What sort of finish will you use?
Re: even possible?
Finished product!
- ROKCRLER
Re: even possible?
That turned out great! Thanks for sharing your photo. Is that a textured finish?
Re: even possible?
Yes, it is wrinkle black powder coatadbuch wrote: Wed Feb 01, 2023 8:39 pm That turned out great! Thanks for sharing your photo. Is that a textured finish?
Re: even possible?
Thanks! The finish turned out great.
