Yes i got a file from langmuir sharing site and there is a tool posted that i would like to use in my blacksmith shop. I loaded it in steet cam and i kept on getting a error saying the layer does not exist. I'm still learning fusion so bear with me.
am i doing something wrong of does the dxf need cleaned up. i see a few extra dots on it and am still trying to figure it all out.
dfx file not working with sheetcam
- East German
Re: dfx file not working with sheetcam
Test this!
Peter
Peter
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
- WyoGreen
Did you pick the correct layer when setting up the cut operation in Sheetcam? Quite often the cutting operation layer box has the layer name from the last file cut, not the current file layer name.
Router
Laser
Router
Laser
Thanks East German! Worked perfect. Also WyoGreen thank you for pointing that out also. The new one worked great but I still could not get it to work after putting in the layer name.
Thanks again for all the help!!!
Your file only needs linking to join all the nodes into a single closed path.punksable wrote: ↑Sun Apr 19, 2020 1:51 pm Yes i got a file from langmuir sharing site and there is a tool posted that i would like to use in my blacksmith shop. I loaded it in steet cam and i kept on getting a error saying the layer does not exist. I'm still learning fusion so bear with me.
- _jay_
Hi, i'm going to cut one, so i edited the file to make a single layer, and made the entity a single block as well.
Try it out if it works for you.
The learning curve is exponential AKA "never ends " !
Yes Jay,
That's exactly what you want.
