Gas Fire Pit?
SlagBandit
Gas Fire Pit?
Post by SlagBandit »
Not sure if this is the right place to post this. I have a construction contractor who wants one of the square pits but with a gas burner for a customer he has. I haven't built one like this yet but have built many square pits. The picture is similar to what he is wanting. He is wanting to use the glass beads to fill it also and still have the designs cut into the sides. Just wondering if anyone has built something similar? Any info is much appreciated!
Torchmate 4x4 Growth Series
Hypertherm Powermax 45
Torchmate 1 5x10
Hypertherm Powermax 85
Miller 225 MIG
Miller 210 Syncrowave TIG
Gamelord
4.5 Star Member
4.5 Star Member
Re: Gas Fire Pit?
Post by Gamelord »
I haven't built one like you are asking, but have done quite a few outdoor gas firepits in tile/rockboard w/rock siding. You should be able to just insert the gas burner and fill with glass beads and be done with it. You wouldn't need to do any mods to the drawing except for how/where you will attach the gas/propane. I assume your contractor will have a way to do this so ask him. If it is just notching the bottom for the hose to come through that should be pretty easy. On the bottom of the pit, just make a solid plate with a hole for the gas line to go through (unless it is going to be plumed out the side). The burner should come with mounts that just screw into the bottom plate. Anything less that 14 ga you should be able to use simple self tapping screws. Thicker you will probably need to drill and use some small bolts.
I don't know how the beads will look through the cutout designs on the sides. They may glow but I am thinking they will not so that may be something you will want to test beforehand to see how it looks. If the beads are going to be below the cutouts then the fire will glow through, if the beads cover the cutouts/designs then they may not be very visible. Normally you only have about 4-5 inches of glass beads in the pit, just enough to cover the burner. Burner usually sits about 1.5 - 2 inches off the bottom of the pit. Here's an idea....you could put a plate on the top that is just down 4-5 inches from the top to mount the burner onto, leaving the cutout designs visible below the plate and then put in some LED's to light the bottom. You could get different colors and such.....may be a pretty neat.
Interesting idea and should be neat to see how it works. I don't see any issues as far as building it. I would get the gas burner before making the pit just to make sure it is going to fit ok in the bottom.
bhamer62
Re: Gas Fire Pit?
Post by bhamer62 »
http://firepitoutfitter.com/
http://www.woodlanddirect.com/
Been on my to do list for awhile, put a false bottom in about half way up, make all cut outs above that line, bury a pancake tank under the false bottom
Re: Gas Fire Pit?
Post by tnbndr »
Yes, get your parts before building. The burners come in many sizes and shapes.
Also, I would run a 4" straight up from the bottom to create a pan for the burner and beads, then angle the sides out with the pattern. Otherwise the beads may want to spill out the pattern if openings are large enough. Also the beads are not cheap so it will take a bit of $$$ to fill this pan up.
Post pictures when done.
SlagBandit
Re: Gas Fire Pit?
Thanks for the input! Will see how it comes out. Just thought as many "pits" are built and shown on here that someone has built one before.
Torchmate 1 5x10
Miller 225 MIG
SlagBandit
Re: Gas Fire Pit?
Well it worked out!
Torchmate 1 5x10
Miller 225 MIG
bhamer62
Re: Gas Fire Pit?
Post by bhamer62 »
Looks real nice! If you get a chance post a pic of your bottle mount too. This would sell better to people who live in places that require spark arrest screens on open fire pits that burn wood plus the flame is much more suitable for use with a cooking grate.
SlagBandit
Re: Gas Fire Pit?
bhamer62 wrote:Looks real nice! If you get a chance post a pic of your bottle mount too. This would sell better to people who live in places that require spark arrest screens on open fire pits that burn wood plus the flame is much more suitable for use with a cooking grate.
No bottle! This was hard lined in through the concrete from a large outdoor tank.
Torchmate 1 5x10
Miller 225 MIG
Gamelord
4.5 Star Member
4.5 Star Member
Re: Gas Fire Pit?
Post by Gamelord »
That came out awesome, nice job. Now I gotta do one for myself. :)
Re: Gas Fire Pit?
Looks like a better control of the fire and flames the finish should last longer.
When your done you just turn it off. :)
plasma88man
Re: Gas Fire Pit?
Post by plasma88man »
Is there a pattern for this one posted?
rezman
Re: Gas Fire Pit?
Post by rezman »
Looks great SlagBandit !! Just curious, how does the paint hold up ? I make those same fire pits but for wood. I use the RustOlem BBQ paint. Over time the paint gets dingy looking. im curious what the paint job looks like burning gas ? I wasn't sure if it will rust real bad ?
SlagBandit
Re: Gas Fire Pit?
rezman wrote:Looks great SlagBandit !! Just curious, how does the paint hold up ? I make those same fire pits but for wood. I use the RustOlem BBQ paint. Over time the paint gets dingy looking. im curious what the paint job looks like burning gas ? I wasn't sure if it will rust real bad ?
I use the same paint! Just hit with wire brush and water hose let dry and retouch in spots.
Torchmate 1 5x10
Miller 225 MIG
jwallmuth
Re: Gas Fire Pit?
Post by jwallmuth »
where did you get the burner at? I been looking online and they seem really pricy
Re: Gas Fire Pit?
Post by tnbndr »
Yes, they are pricey, just have to add that cost to the price of the project. I use this place.
http://firepitoutfitter.com/?gclid=COfF ... gQodxYsGFw
jwheeler11
Re: Gas Fire Pit?
Post by jwheeler11 »
What are the dimensions of your fire pit? I cant seem to make one that looks so proportioned!
Nacs Fab
Re: Gas Fire Pit?
Post by Nacs Fab »
Very Nice, hey where are you from? I live in Columbia, MO where the MIZZOU Tigers Are!
G540 with LCTHC by candcnc
all built... by me...
gram0093
Re: Gas Fire Pit?
Post by gram0093 »
So Cool! Great work, I'm looking to make a similar one for a school auction fundraiser
Re: Gas Fire Pit?
Post by tnbndr »
Most are 24"x24" at bottom and flare out to 36"x36" at the top.
https://plasmaspider.com/viewtopic.php? ... it=firepit
