New to corel
New to corel
Ok, so Ive just downloaded the trial for corel x7. It's pretty foreign to me as I've used Autocad LT almost exclusively and havent had a need for any artwork type stuff. The whole raster, vector stuff is new to me as well, but I understand the difference. So I'm hoping someone can help me out. I was able to thanks to youtube, convert a jpg to a dxf. If I go there the easiest way, I have no idea. But heres my current dilemma. On this drawing I have an outer contour that I'd like to keep. I have an inner contour that almost goes all the way around the outer contour. If I kept that inner one as is, the whole thing would be pretty flimsy. How do I break up that contour so its not solid? Also, any tricks to get from jpg to dxf? I honestly couldnt tell you how I got there.
- Team Tracker
Re: New to corel
Select your grouped objects by clicking on it with the Pick tool, now drop down the Object menu from the top of your screen and scroll down to the Group fly out and select Ungroup All Objects. This should ungroup them so you can work with each object individually. Good luck ![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
1-800-590-7804
Re: New to corel
That didnt really help much. The object was already ungrouped. I just have no idea how to work with them. I get how to remove nodes, but that doesnt help me either. I want to delete the line that connects the nodes....Forgive me if my terminology is off. This is completely foreign to me.
Re: New to corel
Google is your best friend.
Search for corel videos on you tube. There are thousands that will be able to help.
HTH
Gary
HTH
Gary
Candcnc DHCTII Electronics
Sheetcam, Mach 3
Corel Draw 8, V Carve Pro
Miller CTS 280 Miller Mig
Sheetcam, Mach 3
- Gamelord
- 4.5 Star Member
Re: New to corel
Right click on the contour and select "Break Contour Apart" from the flyout menu. Then you can edit / move both pieces of the contour separately.
- Gamelord
- 4.5 Star Member
Re: New to corel
If you want to remove a section of a line, click the node tool (Shape tool on newer versions) then select the lined object you want to edit. double click on middle of the section between the two nodes you want to remove (this adds a new node where you double click). Then click the icon on top that breaks the node apart, then select both ends of the broke apart node and hit delete. This will delete the two nodes (created when you broke the single node apart) and also delete the two lined segments going from the broken apart node to the next closest fixed nodes. If it removes more than you wanted it to, just undo -> add in a new node(s) where you want the segment(s) to stay -> repeat the delete function.
Hope that helps.
If this does not make sense, let me know and I will try to do some drawings for you.
Hope that helps.
- 4.5 Star Member
Re: New to corel
+1grindergary wrote:Google is your best friend.
Search for corel videos on you tube. There are thousands that will be able to help.![]()
HTH
Gary
That's the route I took plus Google for Coreldraw courses and books. You can go the "ask one question at a time route" but it's painfully slow. You can skip a lot of course material because we don't need the colour side of things, we're more interested in tracing, and dealing with lines, outlines, nodes, etc.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
