new toy Plate Roller
All topics related to bending, forming, notching, drilling, saw cutting, etc.
ggeh
Re: new toy Plate Roller
Post by ggeh »
Thank you Acourtjester for sharing the pictures of the roller. I made one just like yours and it works to. I didnt have a project to make yet with it but I always wanted one. I had a motorized worm drive taking up space in my garage for the last 20 years and I finally found a use for it. Very happy thanks again, Gary
Happy to help great project. :)
Have fun
blackcatmetalworks
Post by blackcatmetalworks »
Great project! How are the 3 components of the rollers joined together? Welded? Pinned? If welded any issues with warpage? Thanks!
If you are talking about the rollers, I tack welded the shaft and DOM tubes at the ends to form a solid roller. I just ground a notch and filled the notch with welding.
blackcatmetalworks
Yes that is exactly what I was asking. I appreciate the pix - Thanks!
kdahep
Post by kdahep »
Would I be able to get the plans for this plate roller also? This would work great for wheels and other items that I have been doing on a Shop Outfitters roller and would be able to do a lot wider also. Great job on both of the projects and very impressed on the star embossing .
Thank you
kdahep
I don't have plans per say but if you PM me with your email address I will supply you with any info you want.
studio87
Post by studio87 »
Well I have mine almost finished , Its actually working but need to fine tune it and get it cleaned and painted up / Thanks acourtjeter for the information . not sure how to add photos but will work on getting a few posted of it .. :D
4x8 Delusional designs cnc
Hypertherm 45xp
Kobalt 60 gallon
Happy to help :D Just a little pay back for the help I have received :lol:
BAR M
Post by BAR M »
That is one beautiful design and fabrication. I can only say WOW!!!
tylerd
Post by tylerd »
Yes, this is awesome Jester! Can you tell how much you have into it roughly? Been looking at the crappy 3 in 1's out there will barely do 20ga and everyone wants 90% of retail for used!! Also if you have plans, part numbers or all of the above I would love to get a set!
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
C&CNC Bladerunner Servo
DTHC IV Feather Touch
HyT-Connect DCP-01
Sheetcam Inkscape QCAD
Hi tylerd
I cannot give a accurate cost as I used some of the metal I had laying around. I could send you info and where I bought the sprockets, bearings, and the tubing so you could check the prices. Just PM me with your email address (a non-Yahoo would be best)
tylerd
Post by tylerd »
PM Sent
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
Just PM me with your email address (a non-Yahoo would be best) :lol: :lol:
PM sent too
Gcf6203
Post by Gcf6203 »
need to build one of these, does anyone have a source for the gears and chain? what number of teeth and pitch?
Parts for Plate Roller ordered from Surplus Center
#50-10 10' Box Of #50 Roller Chain
Item Number: 1-1163-50
17T 1/2 Bore 50P Idler Sprocket
Item Number: 1-2410-17-A
19T 1 Bore 50P Sprocket
Item Number: 1-2124-19-E the roller uses 2 of these
Philip Kleinsasser
Post by Philip Kleinsasser »
Truly, a master at work....
I am so humbled.
Nacs Fab
Post by Nacs Fab »
I cannot wait to start this winter Project. Thank you acourtjester for all your knowledge you bring to this forum.
G540 with LCTHC by candcnc
all built... by me...
:-D Happy to help
Bobcat320
Post by Bobcat320 »
I have been trying to design something like this in my mind for months! Your idea and pictures finally brought it all into focus. I am assuming you nested the 3 pieces together to form one roller, with the solid round stock being used in the carrier bearings?
I realize this is an older thread, but do you happen to have the dimensions of the 3 pieces?
Thank You for sharing this,
Carl
PlasmaCam DHC2
Hyperthem PM65
Edwards 25T Ironworker
Yes on the 3 parts for one roller, here is a PDF with some dimensions.
Bobcat320
Post by Bobcat320 »
Thank You!!
PlasmaCam DHC2
Hyperthem PM65
bigcreek
Post by bigcreek »
That is really, really neat. How thick was the metal you pressed the star shape into?
The finished star was 18 Ga, and the star press was 3/16" or 1/4"
Return to “Metal Bending, Rolling, Notching, Drilling, Saw Cutting”
