little help please
deejay
little help please
Post by deejay »
hey still new to sheet cam I got too (pp) that I find work one is NO thc and the other is with both are eazi (pp)
the problem im having is the the pp with out thc runs fine on all arcs corners lead in and lead outs
the pp with thc stops after every arc corner leadin and outs. when I put both pp side by side I cant see any difference ? can anyone help im not very good at all this code just learning
Re: little help please
I am guessing here but it sounds like the THC pp is looking for the Arc OK signal.
Or there could be a path rule being used that you don't know about. You can check these locations, this is where you can find them if you do. Either will show if they are there.
deejay
Post by deejay »
I think we might of found it one pp is using m08 on arcs and we commented it out no more stops but just need it a little smoother ill keep playing with it as for path rules I have one for lead out but it doesn't do a thing
deejay
Post by deejay »
well that back fired
Another thing to check is under the Tool drop down at the top make sure no path rules are shown there, I have seen where that will override the other locations.
deejay
Post by deejay »
it has to be with the pp and my controller.... something stupid but when you don't understand code very well ...well you get my point tried asking les but ya that was a no go . I been it talks with the software designer of my controller and has been a big help ….nowI just need someone that can do me a solid pp
deejay
Post by deejay »
ok been working with les and we got 99% need that 1 more and were good with a standalone controller no more pc/laptop for me
Are you using an Arduino based controller I have seen these for Router based tables??
deejay
Post by deejay »
no not Arduino
Return to “SheetCam”
