Bought a new 4x4 table from Dan at LDR, have had it for about a month now and slowly getting the hang of it,
few things , first the quality. absolutely top notch, I looked around for quite a bit before i decided on LDR, I would recommend to anyone, very solid and well built .
second , the support. Dan knows these machines inside and out. period. he has had the answer to every stupid question and situation I've gotten myself into. --also very patient and responsive.....
Looking forward to many years of cutting
thanks Dan.
thoughts on my new LDR table
Re: thoughts on my new LDR table
Dan is an awesome Guy! Great to work with.
LDR 4x8 w scribe
Miller syncrowave 250
Hobart ironman 230
Baliegh tn 250
Bantam 12 ton 48"
JD2 model 32
Hobart ironman 230
Baliegh tn 250
Bantam 12 ton 48"
JD2 model 32
- ColoradoWayne
I've had my LDR table for over 5 years with the same experience. Still running strong!
Wayne
LDR Motion Systems 4 x 4 water table
Hypertherm Powermax 65
- tnbndr
I have had my LDR 4x8 for over 6 years with nothing but minor, mostly operator errors. I just had an issue with the gantry twisting, sent Dan an email with a video. Within an hour he emailed me his suggestion for a solution, and of course it worked. Simple problem that I had not thought of. Loose connectors at the control board!!!
- cstroke
I've talked to Dan when I was getting ready to get a new table. I ended up going with what I knew.
I talked to him several times and he gave me a good feeling that if I got a table from him that he would be there for me. If I end up looking for another table I'll certainly be talking to him.
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
Thank god, I thought I was the only one with dumb questions for Dan...lol
