Delayed arc start
Delayed arc start
I have a 4x4 ezxy cnc (local manufacturer) plasma tavle with an Everlast 60s plasma cutter. The cut quality is fine but Im having problems with the arc start. The torch will start moving before the arc is fired and Ive been getting around this by running a half inch or longer lead in but thats not always enough and it doesn't help on cut paths where theres no room for a lead in. Ive tried the Pierce delay in sheetcam but it doesn't make any difference, its set at like 2.5 seconds and it doesn't wait any longer than if it was set at 0.1 seconds. Im running the thc1000 post processor, is there something I can change in it to add a pierce delay or wait for arc ok?
Re: Delayed arc start
I would look at another Post Processor, one of the members here had a post about changing the pierce time to milliseconds in the post processor, he is RobertSpark.
I tried a search but could not find his post maybe he will see this and reply
Does your cnc controller have an ARCOK input?
You need to provide a bit more information on your controller and software please.
its easy to change the post processor / sheetcam, but I suspect that your controller may not be set up for plasma cutting and when the M3 is sent the machine will start to move without waiting for the ArcOK
to change the units in sheetcam
Go to >> Options >> Application Options >> Units
Change "Time" from "ms" to seconds or visa versa.
Restart sheetcam and all of the Time settings will be changed to the new units and output from your post processor accordingly.
Im not sure if my controller has an arc ok input or not, Ill open it up tonight and find out the specs on it. Thanks rob I never even thought about the units Ill check that tonight too
Thanks Robert made the change myself, interesting SheetCam just posted a new update first in a long while, at-a-boy Les
For plasma, the sequence of events (in simple / crude form) is suppose to be something like this:
Move to pierce location
Torch Touchoff
Move to pierce height
M3 ---- starts torch + waits for ArcOK
when arc transfers, controller receives ArcOK signal
Torch now waits the pierce duration set
Once the pierce time elapses the machine will drop to cut height
and moves off in a XY G1 / G2 / G3 motion direction (controlled feedrate)
there are other variants for puddle jump it ramp pierce and THC sample and hold etc.... but for the vast majority of simple (3x digital output) UP/DN/ArcOK torch height controllers it will be something close to the above.
Torch Touchoff
Be careful with the update.... there are a few postings on the sheetcam forum with users having issues and things changing....acourtjester wrote: ↑Wed Sep 04, 2019 10:58 am Thanks Robert made the change myself, interesting SheetCam just posted a new update first in a long while, at-a-boy Les
Always best to give the update a bit of bedding in time before you upgrade.... especially if your setup is money related / feeds you
Thanks but I have never had a problems with upgrades, other then reloading my tools in the past but seem to have them all now OK.
Nice of you to inform with this post.
Ok so I found the issue, my controller is a cheap ebay thing that doesn't have any extra inputs so I cant add an arc ok signal which explains why some parts randomly dont cut. The other issue was even though sheetcam is set to seconds mach3 reads it in ms. Thats no big deal though Ill just start programming in ms
Nice easy fix
yseguy wrote: ↑Thu Sep 05, 2019 11:59 am Ok so I found the issue, my controller is a cheap ebay thing that doesn't have any extra inputs so I cant add an arc ok signal which explains why some parts randomly dont cut. The other issue was even though sheetcam is set to seconds mach3 reads it in ms. Thats no big deal though Ill just start programming in ms
Which controller do you have (photo? name? model?)
It doesn't have a name on it at all but there arent any spare pins
How do you like that Ezxy unit overall ?
Did you get your problem fixed ?
