Arclight Auto Tracer for non-Arclight tables
I am interested in using the Auto Tracer on a non-Arclight machine. I have a PlasmaCAM DHC2, a CNC Router Parts Pro4848 running with Mach3, and an Avid CNC Pro2448 running with the Centroid Acorn controller. I have not been able to find any information online as to exactly how the Arclight Auto Tracer interface works. It obviously traces a pattern and creates the corresponding vector file in dxf format. My question is how it interfaces with the cnc controller to drive the motors to do the actual trace. I will appreciate any of your input.
David Buchhauser
BTA Plasma
Re: Arclight Auto Tracer for non-Arclight tables
Post by BTA Plasma »
Several companies try to claim it but it is just scanything from sheetcam.
Please elaborate. Are you saying it only works with sheetcam, is manufactured by sheetcam, or what?
lockeyone
Post by lockeyone »
Epilog Mini 24 60watt, 2013
Thanks! I'll take a look at that.
I can't seem to find any information on the hardware requirements for Scanything. I have a 4x4 router table (CNC Router Parts pro4848). I am using Mach3 with the Warp9 ESS to run the table. The ESS/controller connects to the computer using an ethernet cable. The computer is Windows 7 - 64 bit. I have downloaded Scanything V1.0.16 from the Sheetcam website and followed the instructions for Mach3:
"Instructions for installation with Mach3
Download and install Scanything then run Mach3 and go to Config->Config plugins. Enable the SheetCamRemote plugin and restart Mach3. To test the connection, enable the drives on your machine and check if the jog buttons in Scanything work. "
Does a video camera need to be connected in order to test the connection by enabling the drives and checking to make sure the jog buttons work?
Since I can run Mach3 Mill on my desktop office computer (not the computer out in the shop that I use to run the cnc) and I have downloaded and installed Scanything onto this computer, should I be able to test the jog buttons without being connected to the cnc? I can use the keyboard to jog in Mach3 Mill, and the display shows the movement on the readouts without any hardware being connected.
When I open Scanything, the jog buttons are not active.
I have not yet purchased the video camera. The Scanything description says: "It is designed to work with a USB video camera"
In reading thru some of the other posts, they talk about using a parallel port for the camera, and that there might be a limitation of using Windows 32 bit operating system. Also - do I need a registration key in order to use Scanything?
Do you have any specific recommendations as to a suitable video camera to use here?
I will appreciate any input you can provide.
I receive the following error messages when starting Scanything. I do have he plugin (SheetCamRemote.dll) installed in the C:/Mach3/plugins folder.
Any ideas what I am doing wrong here?
22:07:09: Checking for updates...
22:07:09: Not connected to machine
22:07:09: Error: file '', line 1: '=' expected.
22:07:09: Error: file '', line 2: '=' expected.
22:07:09: Error: file '', line 3: '=' expected.
22:07:09: Error: file '', line 4: '=' expected.
22:07:09: Error: file '', line 5: '=' expected.
22:07:09: Warning: unexpected " at position 89 in '"https://www.sheetcam.com/Scanything/Upd ... re</a>.</p>'.
22:07:09: Error: file '', line 7: '=' expected.
22:07:09: Connected to update server
Post by djreiswig »
I believe you need a license for Scanything to work. If you contact Les @ SheetCam he will probably give you a trial to test it out.
Thanks for your reply. I have just sent an email to Les at SheetCam to inquire about a trial license.
BTA Plasma
Whatever you have for motion control must be running and ready to jog. Also there is a north, south...east..west for the camera. It must be rotated correctly to calibrate. Be aware that scanything is very accurate...often too accurate. Also on the sheetcam page it lays our the requirements. A powered usb cable and supereyes 640 usb camera will do it besides software. Simple. We were an early adopter of the system but it just didnt meet good enough standards for the bulk of what our customers asked for.
I looked at the sometime back, one thing is the video camera needs to one that is like a microscope,very fine detail close up type.
These cameras attach via the USB port and that is why you need the plugin from SheetCam. The way it works is the color difference between the line and the background, it moves to keep the line in the center of its view. I cannot see how that would work without movement of the table that keeps the line in the view. Your manual movement of a line would be very hard due to the precise tracking of Scanything.
Les is very good about trial versions for your testing.
BTA Plasma wrote: Sun Feb 23, 2020 9:35 am We were an early adopter of the system but it just didnt meet good enough standards for the bulk of what our customers asked for.
Please elaborate on the specifics of why it didn't meet your customer's requirements.
