Acid Patina On Galvanized Steel~
steelfx
Post by steelfx »
Here's a couple of samples I worked up this a.m.
Copper FX™_on_Galvanized_Steel.JPG (154.53 KiB) Viewed 2031 times
Galvanized_steel_coated_with_RUST FX.JPG (138.36 KiB) Viewed 2031 times
Rust FX™_on_galvanized_steel.JPG (162.3 KiB) Viewed 2031 times
AnotherDano
Re: Acid Patina On Galvanized Steel~
Post by AnotherDano »
Nice, Bill.
That's some interesting 'looks' to offer the customers.
Keep it up!
Dano Roberts
droberts@ironpequod.com
PlasmaCam DHC-2 v3.11
Hypertherm PowerMax-30
steelfx
Post by steelfx »
AnotherDano wrote:Nice, Bill.
Keep it up!
Thanks. i've got a customer in ID that's building a "Silo Home" and wants the entire exterior done in a patina finish.
Each curved panel will have to be patinated & clear-coated before assembly.
These are single-stage samples, e.g. one patina. Quick & Easy. Torch, Black or Bronze could be added to the Rust FX
or Copper FX for even more dramatic patinas.
Arc Innovations
Post by Arc Innovations »
Hey Bill, what do you use to clear coat your art work? The stuff I use doesn't seem to have a good gloss to it?
Thanks, Gary
Keep it up!
Arc Innovations
http://ai-metalworks.com
steelfx
Post by steelfx »
I use DELTRON DC3000. You can find it at any PPG Dealer that caters to the auto-body shops. It's also available on my site. It's definitely the best I've ever used.
Bill
Post by BrianMick »
Gary, a while back I asked if you had ever used copper fx on galvanized, you said not yet, so I tried it and it just turned black on me, what am I doing wrong can you tell me......by the way that looks great
steelfx
Post by steelfx »
BrianMick wrote:Gary, a while back I asked if you had ever used copper fx on galvanized, you said not yet, so I tried it and it just turned black on me, what am I doing wrong can you tell me......by the way that looks great
Brian,
I've done galvanized, just didn't have any photos until now. You have to vaporize the zinc, first.
A quick (2-3 minutes) in HCI/H20-1:1 will do the trick. I use straight HCI 35%, but it's a very violent, nasty
way to go. Puts off a lot of green smoke & hydrogen gas, so be careful & wear proper PPE if you do it.
Straight HCI only takes 3-5 seconds!
Rinse with water, apply the Copper FX, force-dry & seal. It's really easy.
thanks,
Bill (not Gary)
:D
Post by BrianMick »
Brian,
thanks,
Bill (not Gary)
:D
Bill( not gary), I knew that.....dont know what I was thinking......sorry
Thanks for the info, I will have to give that a try
