https://forum.sheetcam.com/viewtopic.ph ... 558#p27557
in an altruistic effort to help Les and ourselves as sheetcam users and advocates given it will be in all of our best interests to pick up any issues if we can with our normal workflow, it is best if you are able to to given the current beta version a test and provide some useful comments
sheetcam Beta Testing
Re: sheetcam Beta Testing
Hi Robert
I have been using the sheetcam for a while now, I think i have found some small bits ill take note of them and pop them on here
Ok first problem for me, when adding a shape from the built in library
Would it be possible to have it added to the parts section as an individual part not as a layer on your existing nested parts
Sounds good, I have had a couple things worth mentioning however I will get the beta version installed, work with it, and post back to the sheetcam forum link in your original post with any useful commentsrobertspark wrote: ↑Sat Sep 19, 2020 7:16 am https://forum.sheetcam.com/viewtopic.ph ... 558#p27557
