Reckon this can be traced?
I never ask for help on conversions, I stick to simple black and white traces. Just want to know of any tips to trace this using V-carve. That's the program that came with our table and the school doesn't give us a lot of wiggle room to get any other program. Any input welcome.
Re: Reckon this can be traced?
Are you planning on plasma cutting, cnc wood carving, or? Since you say VCarve Pro came with your table - I would assume you are planning to do some engraving on a cnc router table. Here is my tracing with VCarve Pro, you can see the settings I used. You can play around with adjusting Noise Filter and Bitmap Fading and preview the results after each adjustment. This will need some node editing in order to create a usable cut file. If you were planning to do cnc plasma cutting, then I would assume that you might be planning to use a layered approach with different colors to match the original.
You might also consider contacting one of the professionals for a quote for a manual tracing of your image.
https://www.plasmaspider.com/viewtopic.php?f=98&t=27175
DesignShop Ask for Dave
Designs by DeLap Ask for Ben
Robin Hill Machine Ask for Julie
DXF Guy Ask for Don
DXF Guy Ask for Don
Oooh thats a tough one, I would never be able to make that auto trace, it would be a full on draw from scratch for me.
- Larry83301
See if you can auto trace this one, OK.
Larry - that one looks cleaner than the results with VCarve. What program did you use?
- Larry83301
I converted it to B & W with Phto2sketch and cleaned up some of the background with Scan2cad. With a little time you could take out all the background clutter in Scan2cad, I spent about 5 minutes in total converting this one.
Larry - which version of Scan2cad are you using? One of the older versions, or the current expensive version?Larry83301 wrote: Wed Oct 28, 2020 11:29 am I converted it to B & W with Phto2sketch and cleaned up some of the background with Scan2cad. With a little time you could take out all the background clutter in Scan2cad, I spent about 5 minutes in total converting this one.
- Larry83301
Mine's around ten years old but it still works! If it ain't brokeadbuch wrote: Thu Oct 29, 2020 3:42 amLarry - which version of Scan2cad are you using? One of the older versions, or the current expensive version?Larry83301 wrote: Wed Oct 28, 2020 11:29 am I converted it to B & W with Phto2sketch and cleaned up some of the background with Scan2cad. With a little time you could take out all the background clutter in Scan2cad, I spent about 5 minutes in total converting this one.
