Easyscriber on Flashcut software with Hypertherm 85
All topics related specifically to the EasyScriber drag style scribe & engraving tool.
Metal Bender
Post by Metal Bender »
Hi,
Trying to set up an Easysriber on a table using Flash Cut controller and software . Fast Cut 4x8 Icon , Hypertherm Power Max 85 plasma .
It will drag around and make lines satisfactorily for my purpose (marking bend lines) . Problem is it never raises up between cuts , holes etc.
Never see the Z axis move or jog . Have watched all the you tube videos ,tried combinations of different setting ,seem to be missing something .
Any clues would be appreciated . Hope I am asking correctly ,enough detail . This is my first foray into a forum .
Thanks Metal Bender
EasyScriber
Re: Easyscriber on Flashcut software with Hypertherm 85
Post by EasyScriber »
Hey Nick, contact the guys at FastCut they have created a post specifically for the EasyScriber. They can email it to you and you will be set
BTA Plasma
Post by BTA Plasma »
You should be able to set your tip at cut height setting Z below the sheet .010 and uncheck touch offs. You can also trick it into thinking there is an arc ok.
EasyScriber
BTA Plasma wrote: Fri Nov 27, 2020 12:05 pm You should be able to set your tip at cut height setting Z below the sheet .010 and uncheck touch offs. You can also trick it into thinking there is an arc ok.
:Like :Like :Like
Koenbro
Post by Koenbro »
EasyScriber wrote: Sat Nov 28, 2020 3:54 pm
:Like :Like :Like
@EasyScriber: Any tips on a SheetCam to Mach4 workflow for the Easy Scriber? Thank you!
Avid CNC RouterParts Pro 4'x2' with Hypertherm 45XP
EasyScriber
Koenbro wrote: Fri Dec 18, 2020 9:35 pm @EasyScriber: Any tips on a SheetCam to Mach4 workflow for the Easy Scriber? Thank you!
Check this link https://theeasyscriber.com/settings.html for suggested Sheetcam settings that may help you out :Like
Return to “EasyScriber Drag Style Scriber for Hypertherm”
