help with lead in error
bp4511
Post by bp4511 »
How do I remove the lead in error on this design? I've tried to shorten and lengthen the lead ins and type and it doesn't clear it. How would I accomplish that thanks for the help.
4x4 Crossfire Pro Cnc Table
Hypertherm Powermax 45xp
ViaCad2D
Re: help with lead in error
Post by djreiswig »
I wouldn't worry about it. All it is telling you is that some of the geometry is too small to fit a lead in. It will still cut fine, it will just pierce and cut without the lead in where it won't fit. Set your lead in to approximately the thickness of the material and let er rip.
bp4511
Post by bp4511 »
Ok thank you !! Will do !!!
ViaCad2D
TJS
Post by TJS »
Do you really need an inside off set. I cut a lot of ornaments this year with names in them and I have found NO Offset works better with stuff like this.
Post by djreiswig »
No offset makes the spaces between the cuts smaller since it's following the path and burning away part of the piece.
Return to “SheetCam”
