Z-axis Micro switch Mach3
Chuckweb
Post by Chuckweb »
Ok, I’m having an issue with the torch not triggering micro/limit switch then raising back up to make the cut. It keeps wanting to drive the torch into the work. I’m also using a pricecnc THC. I set all my ports and pens to the instructions for the THC but it shows my torch up and torch down are active. The THC is running off a st-v3 breakout board. If someone could help I’d much appreciate it.
Chuckweb
Re: Z-axis Micro switch Mach3
Post by Chuckweb »
It’s a wrightcnc table. I have the THC up and down activated in the input. Doe’s the probe need to be activated? Does z home or z++ need to be activated? Also do I need to click the limit override it the setting tab? Everything was working fine until I installed the pricecnc THC. The torch just wants to push into the part instead of hitting the micro switch and coming back up to make the cut.
Chuckweb
Post by Chuckweb »
Well, I figured it out. The whole time it was the test file. I was using.
Always good when you find the problem, and know its fixed :Yay
Return to “Mach3 & Mach4 CNC”
