A chandelier for a local campgrounds cabin.
A few outside entry lights for the same cabin. I wish I would have gotten some good pictures of these, I was fairly happy with them.
Fundraiser dragonfly(similar to the large one I made a while ago) with a custom tag I made with a laser engraver.
A few items.
- cstroke
A few items.
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
Re: A few items.
Those are all very nicely done! Great work. What kind of finish is that on the moon/dragonfly?
- cstroke
Re: A few items.
The dragonfly was translucent powdercoating with a clear powdercoating.
The chandelier was bare metal with a flat clear to make it look older, other accent parts were black textured powdercoating.
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
Re: A few items.
Beautiful work, love seeing how others are incorporating their plasma cutting into other projects
Re: A few items.
What a beauty! Well done
Re: A few items.
Excellent work! Did you tape or vacuum/finger wipe the dragon fly piece?
- cstroke
Re: A few items.
I think he just was careful and let it overlap/blend..
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
Re: A few items.
Not sure if this would work but after viewing videos on small powder coating techniques. I thing if you used a heat gun or other methods to make the metal hot and then sprinkling the powder on the sections you want (powder coating in a salt shaker). The heated metal will slightly melt (collect on the metal) and then finish with an oven cook. This would be very close to the fluidizing powder coating application.
This guy shows the procedure and also used a paint brush to mix colors too.
Re: A few items.
acourtjester wrote: ↑Mon Dec 27, 2021 1:10 pm Not sure if this would work but after viewing videos on small powder coating techniques. I thing if you used a heat gun or other methods to make the metal hot and then sprinkling the powder on the sections you want (powder coating in a salt shaker). The heated metal will slightly melt (collect on the metal) and then finish with an oven cook. This would be very close to the fluidizing powder coating application.
Re: A few items.
They all look great!
