Ferris Wheel
Ferris Wheel
Can anyone help with a ferris wheel DXF?
PlasmaRoute CNC 4 x 4
Corel Draw X5
SheetCam
Baileigh 12 gauge 40 inch box brake
Corel Draw X5
SheetCam
Re: Ferris Wheel
Here's one I found on https://www.CNCzone.com There is a detailed one at https://www.wildwooddesigns.com
Dave Hanks
Dave Hanks
- Dustan
Re: Ferris Wheel
hope this helps its an actual model you can build
Krazy Kutz metal designs
- Dustan
Re: Ferris Wheel
Wow talk about two guys doing the same shit at the same time LOLDustan wrote:hope this helps its an actual model you can build
Re: Ferris Wheel
Freaky ain't it?Dustan wrote:Wow talk about two guys doing the same shit at the same time LOLDustan wrote:hope this helps its an actual model you can build
Dave Hanks
- Dustan
Re: Ferris Wheel
yupDXF wrote:Freaky ain't it?Dustan wrote:Wow talk about two guys doing the same shit at the same time LOLDustan wrote:hope this helps its an actual model you can build
Dave Hanks
Re: Ferris Wheel
Thanks so much!!
Corel Draw X5
SheetCam
Corel Draw X5
SheetCam
- Dustan
Re: Ferris Wheel
not a problem at all I sometimes browse the forum to see if people need something and then go and try to find it and make it cut worthy its good practice and it helps out a few others this one was already done but you get the pictureEagle Mtn Metal Works wrote:Hey Dustan
That is a very nice Ferris Wheel. Thanks for shearing it.
Re: Ferris Wheel
Finally got around to cutting one of these. I redesigned it by adding .125" over-all to the spokes and circles. That helped eliminate some of the warpage. The sides of the A frame are .125" wider. That was an excellent file to work with!
Dave Hanks
Dave Hanks
Re: Ferris Wheel
Thanks. It cut real nice. 14 gage cold rolled.Eagle Mtn Metal Works wrote:HI Dave
What metal did you use to cut it out of? It looks great.
Dave Hanks
