Thermal Dynamics 102 Cutmaster
Is a Thermal Dynamics 102 Cutmaster able to be used on a CNC table?
Re: Thermal Dynamics 102 Cutmaster
Yes. In fact, the Plasmacam Video Manual lists the Cutmaster 102 as compatible and shows the instructions to install the torch control cable which is used to trigger the torch and monitor the divided arc voltage for thc. What table are you considering using with this cutter?
As David mentioned, yes it can certainly be used on a cnc table. Not sure what table you are planning to install this on but you want to find out if the table has auto torch height control and if so does it require a divided voltage signal or raw voltage signal. If it requires a divided voltage signal you will likely want to buy the cnc interface for your 102, if it will work with raw voltage than you can wire it up without the cnc interface pretty easily and save a few bucks.
The Plasmacam torch control cable has the voltage divider incorporated into the cable. But yes - I think it goes without saying that unless your thc can work with raw arc voltage, you will most certainly need a voltage divider to obtain the correct voltage range for your thc.
I have a lot of studying and learning to do but I have read good things about PlasmaCam and user-friendly software.adbuch wrote: ↑Tue Jul 05, 2022 2:38 amYes. In fact, the Plasmacam Video Manual lists the Cutmaster 102 as compatible and shows the instructions to install the torch control cable which is used to trigger the torch and monitor the divided arc voltage for thc. What table are you considering using with this cutter?
Kirk - I agree! Great cutting table and super software.Kirk T wrote: ↑Sat Jul 09, 2022 9:42 pmI have a lot of studying and learning to do but I have read good things about PlasmaCam and user-friendly software.adbuch wrote: ↑Tue Jul 05, 2022 2:38 amYes. In fact, the Plasmacam Video Manual lists the Cutmaster 102 as compatible and shows the instructions to install the torch control cable which is used to trigger the torch and monitor the divided arc voltage for thc. What table are you considering using with this cutter?
![Like :Like](./images/smilies/icon_new_like.gif)
