Arclight Dynamics Questions and Answers
drossmaker
Post by drossmaker »
Arclight Dynamics would like to impart onto you our knowledge. If you have general questions about Sheetcam, Mach 3, Inkscape, Solid Edge, or would just like to chat with someone at Arclight Dynamics about specifics of our products, then make a post and we will be happy to answer your questions. :idea:
We plan on reliably posting answers to your comments every Wednesday. :mrgreen:
We're looking forward to seeing what you have for us.
~Drossmaker
Ghost
Re: Arclight Dynamics Questions and Answers
Post by Ghost »
Should be a great thing, can't wait.
601Metalworks
Richland, MS
Arclight Dynamics 9600
jason@601metalworks.com
little blue choo
Post by little blue choo »
Received my Arclight 9600 about a month ago and haven't got it up and running yet. I have been finishing up a Trackless Train order and haven't had time to get started. I called my electrician today to install a larger electrical service in the rear of my shop. I have a 200 amp service in the front part of the shop and only a 60 amp in the rear. I should be posting questions and CALLING in a few weeks. LOL
Rick
Arclight 9600 4x8 table
drossmaker
little blue choo,
We'll be happy to answer any of your questions.
Here is a link to the specs for your Hypertherm Powermax 65:
https://arclightcnc.com/plasma-cutter/powermax-65/
I hope this link helps.
~Drossmaker
bluefish
Post by bluefish »
Any suggestions on how to set up a crane system (or any solution) for placing large sheets of metal on the plasma table? I am thinking of setting up a conveyor roller on the left side of the table, but I would love to see what solutions other people are using.
Thanks in advance.
-Rich
Post by tnbndr »
bluefish:
Not an Arclight table but a material handling solution.
http://www.plasmaspider.com/viewtopic.php?f=87&t=16152
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
drossmaker
Rich,
Regardless of your set up, the best practice is to have a system that will lower or set your steel onto the table. We would suggest using a magnetic lift, utilizing a gantry crane or jib lift (off of a fork lift).
~drossmaker
Brew Worx
Post by Brew Worx »
Can the computer be mounter on either side? The photos show table right. Is there the ability to mount on the Left hand side like a refrigerator door?
The material loading post above has me thinking of perfect shop floor location. In a large open shop, it may not matter. In a tighter garage bay, its a planning consideration.
Great thread here.
Brew Worx.
Blue Frog Metal Works
Chicagoland
Arclight 4800 :D :D
Hypertherm 45
4 inch tube cutter
Mach 3, SheetCAM, Solid Edge 2D, Solid Works 3D, CREO, Inkscape, and a few cobb webs
drossmaker
In short, we are able to mount our cabinets on either side of the table. We also have a mobile cabinet feature as well, where the cabinet is tethered to the table with a 25' umbilical.
~drossmaker
oregonsigns
Post by oregonsigns »
HI SCOTT, I AM TRYING TO CUT A SLOT IN NEW CHAIN SAW BARS THAT ARE POWDERCOATED AND I AM BATTLING WITH THE TORCH DRAGGING. I DON'T WANT TO HAVE TO GRIND ALL THE POWDWERCOAT OFF. SHOULD I JUST TURN OFF THC? IF SO, DO I JUST BUMP THE TORCH UP A BIT FROM THE METAL? ALSO, HAVE YOU DONE ANY R & D ON A PEN HOLDER. I HAVE THE ENGRAVER, BUT IT PUSHES THE SCRAP AROUND.
RUSS
Team Tracker
Post by Team Tracker »
For sure, just turn the THC off and manually set your torch to work distance to the recommended height specified in your plasma cutters manual. You may need to bare the PC off at the pierce location at the start of your lead in depending on how thick the PC is.
1-800-590-7804
drossmaker
oregonsigns,
Turning off your THC will work. Keep in mind that if there are large undulations in your part you may run into issue. As Reid T stated it is best to use the recommended torch to work distance for your piece. My recommendation would be to make your cuts with the THC off or leave the THC on and bump up your Preset Volts in Mach either prior to hitting run of on the fly; until you see that desired cutting height.
To the plate marker. We have done a lot of R&D. The plate marker will move smaller pieces of steel around. We suggest securing your work down if it is going to be etched on a smaller piece of material.
~drossmaker
Brew Worx
Post by Brew Worx »
With the announcement of the new faster controller, whats the cost upgrade for 2 month old tables? Is it cost effective to upgrade?
Brew Worx.
Chicagoland
Arclight 4800 :D :D
Hypertherm 45
4 inch tube cutter
Brew Worx
Post by Brew Worx »
Hey Team Arclight,
Would this be a good location to ask questions about the standard software that comes on the Arclight systems? Freeware License and what not.....
In particular, Solid work goes stale after 12 months. Maybe a good place of a reference of next steps. Even if the answer is go see the manual on page 12.
Just a thought.
BTW, it seems just like yesterday when we were in Bend getting the awesome training. Cant believe its been almost a year already.
Brew Worx.
Chicagoland
Arclight 4800 :D :D
Hypertherm 45
4 inch tube cutter
drossmaker
Brew Worx,
Are you wanting to update Solid Edge? If that is the case we can email you the license and instructions for the instal. Let us know.
~drossmaker
2015cmax
Post by 2015cmax »
bluefish wrote:Any suggestions on how to set up a crane system (or any solution) for placing large sheets of metal on the plasma table? I am thinking of setting up a conveyor roller on the left side of the table, but I would love to see what solutions other people are using.
Thanks in advance.
-Rich
Without knowing the size of material you plan on working with, one option might be an overhead "I" beam and a trolley.
That will be my plan, then I do not intend to work with much over 3/8"plate. Maybe the occasional small sized 1/2". When
I built my shop I used 4X12 manufactured beams 4 foot on center, so the weight I will deal with will not be an issue.
Brew Worx
Post by Brew Worx »
drossmaker wrote:Brew Worx,
~drossmaker
Hey Guys,
Can you shoot me the License and instructions for the install?
Brew Worx.
Chicagoland
Arclight 4800 :D :D
Hypertherm 45
4 inch tube cutter
seajinx
Post by seajinx »
Shield rides against metal, Somewhere along the line some setting changed and I'm not sure when, where, or how it happened. Need help Drossmaker. I'm using up consumables like crazy. I have the 1200 table with hypertherm 85 using 45 Amp tips machine set at 45 Amps. After about 3-4 minutes of cutting I get error 0-30 on Plasma machine, telling me the Consumable is stuck. I clean it out replace it, clean the shield and it works for about 3-4 minutes. The shield goes down and touches the metal goes up but not far enough to clear the sheet metal.
drossmaker
seanjinx,
I think you might be working with Joe B. on this. Check your plunge safety clearance in SheetCam.
SheetCam > Options > Job Options > Plunge safety clearance ( it will be at the bottom of the window; set to at least .75
~drossmaker
give us a call if you would like further troubleshooting.
Brew Worx
Post by Brew Worx »
Hey there again guys.
I have a very good customer asking me if I can cut Titanium.
Have you guys ever tried Ti?
Brew Worx.
Chicagoland
Arclight 4800 :D :D
Hypertherm 45
4 inch tube cutter
little blue choo
My designedge is asking me to renew my license but every time I go to their website to do so I get diverted to a page trying to get me to update to a new version which I really don't want to do. How do I get the code to enter?
Rick
Rick
drossmaker
Rick,
Are speaking about Solid Edge 2D? If so, shoot an email to sales@arclightcnc.com. We will send you Instructions on licensing and instal. That instal process should take all of 2 minutes.
~drossmaker
