My first table build
I just thought I would share my first build with you folks. Critiques are welcome, you probably cant hurt my feelings, I used to hold the flashlight for my dad. so....
Re: My first table build
Looks like a good start, I am not a fan of 2 motors for an axis, but there are lots of them out there.
A long lead screw can have a whipping action at higher speeds. Have you started on the electronics yet?
Yes, the panel is already built. I figured with a 5ft width the two motors would be better. I am aware of 'whip' but I think I will be able to control it with the way I will be attaching.
Ballscrews are not reccommended for plasma tables as velocity and accelleration are limited.
I'd recommend you look at a rotating nut system as ths eliminates the whip. They are not hard to build; Here is a random example.
Nice. I notice that you are using a MyPlasm system and noted that your wiring is nice and neat and that you have gone to a lot of trouble to keep it all nice and neat.
But what I don't see is any ground wires for your shielded cables when the manual recommends that they all be grounded in a particular way to eliminate some EMI which would be essential for an USB based board.
I am just installing one myself and that is what grabbed my attention, but maybe I am missing something
could he have grounded the shields on the other ends? You don't want them attached on both ends that causes a ground loop.
I used a similar panel connecter and passed the shields through on a pin in the connecter.
I'm with Tom on this one. Connect the ground shield drain wire at one end only to prevent "ground loops" which can act like large antennas for noise pickup.
I get that , and I only commented on it because I saw no obvious common ground and their video tutorials are very specific on how and where to ground the system.
I am not eggspurt on Electrickery.
thank you for the kind words. Yes, you are correct, I do not have the grounds installed as of yet. I wired using what I had on hand at the moment, awaiting the arrival of the better shielded cables. These are shielded but foil shielded rather than braid shield. I have been test running this without the plasma installed to get everything sorted out first. I will re post when I have a completed unit.Dingo74536 wrote: ↑Sun Apr 30, 2023 8:40 am Nice. I notice that you are using a MyPlasm system and noted that your wiring is nice and neat and that you have gone to a lot of trouble to keep it all nice and neat.
Diagram.pdf
Fadal 4020 with 527 control
Haas VF3
Bridgeport Series 2
Clausing Lathe
Millermatic 251
Millermatic 252 with push/pull for aluminum
Thermal Dynamics cutmaster 58
Everlast 82i
Haas VF3
Bridgeport Series 2
Clausing Lathe
Millermatic 251
Everlast 82i
that is a very neat setup. those are some pretty beefy ball srews. If I do not like the performance out of what I currently have, putting a rack and pinion on would be very easy.
Haas VF3
Bridgeport Series 2
Clausing Lathe
Millermatic 251
Everlast 82i
Haas VF3
Bridgeport Series 2
Clausing Lathe
Millermatic 251
Everlast 82i
- SegoMan DeSigns
Both Tom and I use chain, sprockets and a drive line for synchronized movement, it allows you unlimited lengths (at a cheap price) on the runs.prairiecreekmfg wrote: ↑Thu May 04, 2023 3:21 pm that is a very neat setup. those are some pretty beefy ball srews. If I do not like the performance out of what I currently have, putting a rack and pinion on would be very easy.
got a pic to share?SegoMan DeSigns wrote: ↑Thu May 04, 2023 3:57 pmBoth Tom and I use chain, sprockets and a drive line for synchronized movement, it allows you unlimited lengths (at a cheap price) on the runs.prairiecreekmfg wrote: ↑Thu May 04, 2023 3:21 pm that is a very neat setup. those are some pretty beefy ball srews. If I do not like the performance out of what I currently have, putting a rack and pinion on would be very easy.
Haas VF3
Bridgeport Series 2
Clausing Lathe
Millermatic 251
Everlast 82i
Haas VF3
Bridgeport Series 2
Clausing Lathe
Millermatic 251
Everlast 82i
- SegoMan DeSigns
prairiecreekmfg wrote: ↑Thu May 04, 2023 4:01 pmgot a pic to share?SegoMan DeSigns wrote: ↑Thu May 04, 2023 3:57 pmBoth Tom and I use chain, sprockets and a drive line for synchronized movement, it allows you unlimited lengths (at a cheap price) on the runs.prairiecreekmfg wrote: ↑Thu May 04, 2023 3:21 pm that is a very neat setup. those are some pretty beefy ball srews. If I do not like the performance out of what I currently have, putting a rack and pinion on would be very easy.
(6' x 12' cutting area)
Stills
1:28 - 1:37
shows chains and tensioner on the right side
Vids
2:05 - 2:46
Chain Drive in action
6:21 you can see the drive line that turns both side on the far left..
some of mine under construction. video if the 9 th table, on the Google drive.
Just checked out your video Tom. I like your new design concept, very clever!
