How to program a ZERO ALL key
Hi y'all
Still fairly new to this software.
I have a question about key mapping to a wireless controller.
I want to setup a key on the controller to ZERO ALL axis's
I have setup other keys but I cannot seem to find the recipe to allow me to map out the
ZERO X
ZERO Y
ZERO Z
and add them all to one key press on my controller
I hope that makes sense to you guys
ZERO X
ZERO Y
ZERO Z
Re: How to program a ZERO ALL key
Use the G92 command G92 x0y0z0 that will clear the DRO to zero
Thank you , just 1 question........ how would I input that to assign to a button in anti microX for my controller,acourtjester wrote: ↑Fri Aug 11, 2023 2:14 pm Use the G92 command G92 x0y0z0 that will clear the DRO to zero
I am sorry for being a dummmmmasssss
You might have to create a macro in mach & then assign the macro to your button. Or if you are able to run mach screen buttons with your controller, assign the macro or gcode to a screen button and assign the button to your controller. I'm not sure how your controller functions.
If you are using Mach 3 there is a program called Screen 4 which is for adding or modifying things on the screen. Search YouTube for a video on how to do it, it not hard. You can add a short G-code to a button, then do what you are using now to assign a button from the game controller to that button in Mach 3. LinuxCNC has a similar thing using QTPlasmaC you can assign a button on the main page for additional operations.
You could do a search on YouTube use different wording about what your looking for, somebody may have a video on just how to do it.
Many thanks guys
I got it all sorted out using SCREEN4.
Its working good.
Thanks Guys
Its working good.
Thanks Guys
Great thanks for the follow up, may help future searchers with similar questions.
Tom - that Screen 4 sounds like a neat tool! I do run Mach3 on one of my cnc router tables, but have not yet had the need to do any of this fancy stuff with the macros. Thanks for sharing this and I will keep it in mind for future use.
I used MachScreen to do a bunch of custom stuff to.my setup I think I tried Screen4, but it didn't work for me.
Screen 4 took a little bit of figuring out, but got it done in the end.
now i have a Zero All button on my screen set which is now programmed in my cheap ass game controller.
So happy now
Many thanks for your help
Thanks for the update! I'm glad you got it to work for you.tassleholf98 wrote: ↑Tue Aug 15, 2023 8:03 amScreen 4 took a little bit of figuring out, but got it done in the end.
So happy now
Now that you know how to edit screens, that opens up all sorts of possibilities.
When I was running Mach I used screen 4 to setup a button for moving from laser positioning to Torch position. Little add on laser crosshairs and a G-code to position the torch over to that crosshair position. LinuxCNC with QTPlasmaC has add on buttons to do similar things. About 6 are already in when starting QTPlamaC, I just need to learn how to do that. Here is a list of some of the buttons the Rod has setup on his system.
I have a couple that I use to zero off of my scribe and then move the torch to that position and re-zero. The other one moves back the other way in case I need to adjust slightly. Also have a park button. I have buttons to switch my reference from ohmic to the mechanical switch. Buttons to run my scribe, air slide, plasma & flame torch valves. Have a trial run button that changes mach to block delete mode so I can do a test run without the torch and thc without switching the power supply off.
This one took a little post processor modification. I think I posted how I did this on here a while back.
Lots of possibilities.
