Can anybody tell me howto add points to a Corel Draw file so I can use them as drill points in SheetCam?
Thanks!!
drawing points in Corel Draw for a drill routine?
- Tristar500
5X7, 6x11 plasma own design
Mach3,4 SheetCam, CorelDRAW 2020 Inkscape .0.92
Homebuilt 3 axis mill
Homebuilt 5 axis mill
PrimeWeld cut 60
Hypertherm 350
Miller Symchrowave 250 DX
Several mig welders
You are only as old as the woman you feel.
PrimeWeld cut 60
Hypertherm 350
Several mig welders
Re: drawing points in Corel Draw for a drill routine?
I know of no way to create a single point using CorelDraw. Design Edge and BricsCAD both have a Point tool.
Just draw a circle that is .001" in diameter and that will work.
- Scratch
I use Corel draw, and when I need to do a point, I just create a line, then zoom in on it really really close, then drag one of the end points until it’s right next to the other one. Zoom out and boom… single point.
plasmanewbie wrote: ↑Mon Dec 18, 2023 11:57 am Just draw a circle that is .001" in diameter and that will work.
For "drill points" for cnc machining, I would draw the small circle as Plasmanewbie has suggested. That way - the drill bit, endmill, etc. will locate on the center of the circle. It this is just for marking sheet metal with plasma for subsequent manual drilling of holes, then either method should work fine.
