Everlast Plasma Cutter Opinions
Discussion forum for RazorWeld, Everlast, and all other plasma cutters.
cuttinparts
Post by cuttinparts »
The Everlast have peaked my interest lately as I am in the market to replace my dead Hypertherm (too costly to fix it this time).
What is everyones experience with these machines? Do they deliver decent cut quality? Are they reliable?
The overinflated price of a new Hypertherm and the costly sync cartridges are turning me off bigtime.
Would love to hear any good or bad about Everlast. Looking at the 82i with cnc package for myself.
Pretty slick looking unit, if it works as good as it looks I am sold.
Re: Everlast Plasma Cutter Opinions
I don't have their plasma but I have 3 for their Tig units (sold the first 2 to upgrade) happy with them, just get the machine torch of easy mounting.
cuttinparts
Thanks Tom, appreciate it. Hopefully i can hear some plasma users as well before I pull the trigger.
Polargtx
Post by Polargtx »
I have an 82i running on my plasmacam. It is a beast , cuts very well . Some consumables are hard to find , but overall it’s a great machine so far.
cuttinparts
Polargtx wrote: Sat Jun 17, 2023 3:41 pm I have an 82i running on my plasmacam. It is a beast , cuts very well . Some consumables are hard to find , but overall it’s a great machine so far.
Thanks for the reply, gives me a little more confidence. I have been looking for a while and it appears as though the 82i uses the IPT80 torch and many other brands also appear to use this same torch. If this is the case and consumables are the same maybe that would make it easier to get the consumables you need.
Polargtx
Post by Polargtx »
I have found decent range for nozzle sizes(0.65mm 0.9mm 1.0mm 1.1mm 1.2mm ) shielded and unshielded, just not as readily available as some other brands..I run a machine torch with modified drag cap and shielded nozzles.
cuttinparts
Do they specify best amperage to use for each nozzle size?
Polargtx
Post by Polargtx »
Yes,
0.9mm 30-40A
1.0mm 40-50A
1.1mm 50-60A
1.2mm 60-70A
1.3mm 70-80A
cuttinparts
Polargtx wrote: Tue Jun 27, 2023 5:08 pm Yes,
0.9mm 30-40A
1.0mm 40-50A
1.1mm 50-60A
1.2mm 60-70A
1.3mm 70-80A
Awesome, thank you!
IronmanMetal
Post by IronmanMetal »
I talked to everlast today and he said they are coming out with a new torch that uses hypertherm consumables. Its coming out in march.he said it is way better then their regular torches.
Post by djreiswig »
Are they going to use the sync consumables? That's supposed to be the latest/greatest. They're supposed to cut better & last longer than the old multi piece setup. Or do they say.
IronmanMetal
To talk to one of the tachs at everlast, he told me they are coming out with a new torch in march based after the hypothermia and he said the cuts much better
IronmanMetal wrote: Fri Dec 22, 2023 4:02 pm I talked to everlast today and he said they are coming out with a new torch that uses hypertherm consumables. Its coming out in march.he said it is way better then their regular torches.
The Everlast units I have used all were equipped with aftermarket torches (from China and Italy) that used rough copies of the older (about 25 years) Hypertherm torch technology as used on the Powermax600, Powermax1000 and Powermax1250 Hypertherm systems. These use the original blowback plunger style torches that Hypertherm developed and patented in the '80's. The next level of Hypertherm technology used the "spring electrode" blowback technology.....and these torches are used on the Powermax45xp, 65, 85 105 plasma systems. The latest from Hypertherm are the SYNC cartridge systems. Since Hypertherm develops their torch and power supplies together, don't expect the exact same results when using older technology from different manufacturers. I'm pretty sure that the manufacturers of these torches that use "Hypertherm" consumables will not be using the SYNC cartridge technology......at least not until the Hypertherm patents expire! By developing their own torches and power supply technology....the Hypertherm systems use a proprietary up ramping of cut air pressure and current (amperage) at the beginning of each cut as well as downramping at the end of each cut. this functionality dramatically improves cut quality as well as consumable life. Copying an older tech torch will not get this for you. The Hypertherm consumables do cost more at the time of purchase, but have a lower "cost of use" (longer life)....making your actual cut per foot lower. It is the buyers choice......buy the lower cost system and torch up front, or buy the technology that lowers operating cost.
northcj
Post by northcj »
I've been using an 82i on my table for 3 years. Have had an older hand held everlast plasma for at least 10 maybe 15 years. Happy with both. Have no problem finding consumables.
cuttinparts
northcj wrote: Sat Feb 03, 2024 7:44 pm I've been using an 82i on my table for 3 years. Have had an older hand held everlast plasma for at least 10 maybe 15 years. Happy with both. Have no problem finding consumables.
Thanks for the feedback, getting close to pulling the trigger on one.
plasmadyn
Post by plasmadyn »
Hot setup is large Everlast with OEM Hypertherm Duramax Torch - using SYNC Cartridge - we custom make these - results are spectacular - we have put these on Miller 3080, Thermal Dynamics Cutmaster 60i, 82, 102, Primeweld, and LOTOS machines. Turns out the cost is VERY in line with aftermarket parts, some seeing 2k+ pierces. And the idea that there is an arc voltage issue is BS - pushed by those with an agenda.
cuttinparts
That's pretty cool. What price do you sell the torches for?
plasmadyn
Post by plasmadyn »
20 Foot Machine Torch starts at $499 - uses Hypertherm Duramax Parts
We manufacture this torches - and can put them on almost any machine -
Everlast - Miller - Thermal Dynamics - Razorweld - Primeweld
cuttinparts
That is awesome! I will be keeping your setup in mind. Have always wanted to try the Everlast but an not a fan of the IPT torches.
Return to “RazorWeld, Everlast, & All Other Plasma Cutters”
