Bend Relief Lines
All topics related to bending, forming, notching, drilling, saw cutting, etc.
Magic Rat
Bend Relief Lines
Post by Magic Rat »
Hi all I'm looking for advice on size of bend relief lines in 3/8" mild steel if anyone has any experience. I've got oxy but if I can get away without it I'd be interested to hear how you did it.
jmersereau
Re: Bend Relief Lines
Post by jmersereau »
I don't bend 3/8" material in my projects so I can't give you any advise, but just to confirm... you are asking about a break relief cut (or several) that is in line with your bend?
David spoke about in this post from a few years ago https://www.plasmaspider.com/viewtopic. ... 17#p217217
PrimeWeld CUT60
Langmuir CrossFire Pro
4130metalworks
Post by 4130metalworks »
It sounds like with an oxy involved magic rat is trying to bend it by hand or in a vice. What sort of bending equipment do you have?
Post by tcaudle »
Bend metal is a more copmplex process tha it woudl at first seem. There are two main factors: the Bend Radius and the Bend allowance. When you bend metal it shrinsk and grows and it does not end up a sharp 90 deg turn. The thicker the material the bigger the bend radious . So the length of each leg "grows " by an amount of about 1/2 the bend radius length (the Lenght is section ot the circumference defined buy that 90 deg section .
As you get up in thickness there are more factors involved . The are charts by material thckness to give you the "average" bend radius form which you can determine how much the lengs of each leg change. On 3/8 material it woudl be a LOT more than say 11 ga (1/8")
so the position o f the bend line has to take into consideration growth in length it the outsides or inside dimension is important.
On thinner material I use the material thickness to approximate the bend limits and its usually pretty close but not super accurate for tight fits/.
Bending via heat and hammer is a lot less accurate than via a press brake but you need 80- 100 ton Press Brake to bend 3/8 mild steel without preheat/
Sometimes on thicker materials its easier to cut to exact dimension and weld than to try and bend a 90 deg or sharper angle if exact size is important
Magic Rat
Post by Magic Rat »
Thanks for the replies folks sorry I'm on GMT here. Yes I'm familiar with bending allowance. I've never done this with anything heavier than 1/4" and find a min 1/8" line rather than a single kerf works better so was expecting I should go heavier on 3/8". I appreciate your input by the way.
Magic Rat
Post by Magic Rat »
4130metalworks wrote: Tue Jan 07, 2025 5:03 pm It sounds like with an oxy involved magic rat is trying to bend it by hand or in a vice. What sort of bending equipment do you have?
Yes hand bend in a vice probably bend is roughly 10" long.
Magic Rat
Post by Magic Rat »
jmersereau wrote: Tue Jan 07, 2025 3:49 pm I don't bend 3/8" material in my projects so I can't give you any advise, but just to confirm... you are asking about a break relief cut (or several) that is in line with your bend?
Thats exactly what I was looking for thank you for the link.
Magic Rat wrote: Wed Jan 08, 2025 1:16 am
For 3/8" thick x 10" long using manual bending (hold in vise, clamp to top of bench, etc.) and assuming you will be welding it up after bending, I would probably go with slots along the bend line - maybe 3/16" to 1/4" wide. Long slots with short tabs where the bend will occur. I would do a test piece first (as I showed at the post Jim referenced above) to make sure you can create the entire 90 degree bend without the slots "binding". Also, a bit of heat probably wouldn't hurt to make the material more malleable.
Magic Rat
Post by Magic Rat »
Thank you Adbunch. A test piece is a good idea and yes I will be welding it up afterwards. Thanks.
Magic Rat wrote: Wed Jan 08, 2025 3:42 am Thank you Adbunch. A test piece is a good idea and yes I will be welding it up afterwards. Thanks.
You are quite welcome! Let us know how it turns out.
4130metalworks
Magic rat, do you have a press at all? i made a very basic pressbrake attachment for mine, could possibly use the vice if it was heavy duty enough
PlasmaDon
Post by PlasmaDon »
At that thickness, and having to weld all along the edge anyway, why not just make 2 separate pieces ?
4130metalworks wrote: Wed Jan 08, 2025 5:38 pm Magic rat, do you have a press at all? i made a very basic pressbrake attachment for mine, could possibly use the vice if it was heavy duty enough
My little Harbor Freight press brake would work nicely for his part.
cutnweld
Post by cutnweld »
I have found that putting relief in thicker materials seems to result in the remaining material cracking when i applied the bend, so I used to end up making separate pieces and welding together. Now I use the brake with 8x die opening and it seems to work alright unless it is AR plate.
5X10 Shop built table
20x80x32 inch gap lathe
10x40 lathe
10x54 milling machine
2-Miller 255
Miller XMT350MPA
Lincoln squarewave tig 255
12 Ft Ermaksan Brake
Return to “Metal Bending, Rolling, Notching, Drilling, Saw Cutting”
