Thicker plate piercing strategies?
I have a STV 5x10 table with the optimum controller and a hypertherm 85 smart sync plasma . I’ve fought some of the controls and had to really learn the quirks of their system. What I wanted to know about other brands is how do you tackle piercing holes in thick plate like 3/4”- We make a good deal of baseplates and parts with 13/16” holes. When I pierce with a new consumables, they get ruined in a few holes. Any advice or strategies like pre drilling(not sure how to start on that) would be great. Thanks!!
Re: Thicker plate piercing strategies?
If you're using SheetCam, try using the ramp pierce. I don't do much thick plate, and since I have a 65 I use edge starting when possible.
- Joe Jones
If you can drill a simple 1/8" hole at a specific point, you can pierce at the edge of the hole and that will be the same as cutting in from any edge.
PlasmaCam 4x4 and 5x10 w/Upgrades
X-TOOL
(14) LASERS
(2) Apparel Printers
(1) MetalFab Machine
LaserPecker 1 PRO, LP-2, LP-4 +
50 Watt GALVO fiber laser
1,000 Watt 4x8 Fiber Laser
SwiftSHAPE machine
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
MakerBOT Z-18 3D Printer
Bernardo Mach 55 TON Iron Worker
Grizzly G0792 - Roll Bender
Langmuir MR-1
X-TOOL
(14) LASERS
SwiftSHAPE machine
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
Langmuir MR-1
No sheetcam, my machine came with the optimum software. I don’t know if I can use sheet cam.djreiswig wrote: Sat Mar 15, 2025 12:19 pm If you're using SheetCam, try using the ramp pierce. I don't do much thick plate, and since I have a 65 I use edge starting when possible.
That’s what I’d like to do- but I don’t know how to accurately line up multiple drilled pilot holes with the start points of the torch.Joe Jones wrote: Sat Mar 15, 2025 12:30 pm If you can drill a simple 1/8" hole at a specific point, you can pierce at the edge of the hole and that will be the same as cutting in from any edge.
- Joe Jones
It is a bit tricky, but it can be done.
X-TOOL
(14) LASERS
SwiftSHAPE machine
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
Langmuir MR-1
X-TOOL
(14) LASERS
SwiftSHAPE machine
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
Langmuir MR-1
- FabLab
In my opinion your best bet is to pierce in the center of the hole and use a straight leadin I would experiment with raising my pierce and cut height on the holes as well, but .812 hole in .750 it's going to be tough to get good consumable life.
The other thing I have done in the past is setup a job that just does the piercing, use old consumables for that job, switch to new ones and run a second job that does the cutting..
Hypertherm chart says your pierce height should be at .250" so first off I would check to be sure that your machine is piercing accurately at that .250" height. Often what you set on the screen and what it actually is out at the table can be different.
If you find that your torch is lower than .250" when piercing adjust your height to get an accurate .250" pierce height and see how that goes.
Let us know if you pierce height was accurate or not and we can go from there.
What weldguy said is definitely the best place to start. If you can’t get it figured out with pierce heights you could try an easy scriber https://www.theeasyscriber.com/ or my pen plotter https://overthetopfab.etsy.com/listing/1598577295
You would just have to run the marking operation, drill your holes at all of your pierce points, then run your cutting operation.
- Joe Jones
Set up a jig to place a SHARPIE pen into it to DRAW the shapes you are going to cut onto the metal plate, using your cnc table as a plotter. Remember to offset the drawing the same distance as that from the pen tip to the torch tip, and offset it on the same axis (X or Y, or Xn + Yn, etc.) In the drawing mark exact pierce points. Now use a mag drill or a hand drill with a slide jig to drill the 1/8" pilot holes at those points.
X-TOOL
(14) LASERS
SwiftSHAPE machine
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
Langmuir MR-1
X-TOOL
(14) LASERS
SwiftSHAPE machine
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
Langmuir MR-1
- SegoMan DeSigns
The 105 (Non SYNC) is production pierce rated to 7/8" with a 1.25 second pierce delay time, To pierce 1" I delayed that too 2 seconds with good results. Always allow the thickness of the metal for the leads ins if not more when possible. like other posted the center of smaller circles is best. The wiggle lead in was an expensive experiment and now I use the ramp mode.
A peck pierce will mark the pierce points for drilling purposes, A search of the forum will give you multiple results on how to do it.
SegoMan DeSigns wrote: Sat Apr 05, 2025 2:32 pm The 105 (Non SYNC) is production pierce rated to 7/8" with a 1.25 second pierce delay time, To pierce 1" I delayed that too 2 seconds with good results. Always allow the thickness of the metal for the leads ins if not more when possible. like other posted the center of smaller circles is best. The wiggle lead in was an expensive experiment and now I use the ramp mode.
Run the program without cutting, and pause before starting a cut path. this is your piece point. Test fire the torch at this point and this will create a small dimple at the pierce point. Drill a hole here.Eric C wrote: Sat Mar 15, 2025 12:51 pmThat’s what I’d like to do- but I don’t know how to accurately line up multiple drilled pilot holes with the start points of the torch.Joe Jones wrote: Sat Mar 15, 2025 12:30 pm If you can drill a simple 1/8" hole at a specific point, you can pierce at the edge of the hole and that will be the same as cutting in from any edge.
No matter what they call it , pretty sure that is a MyPlasma Control and their limited software so it may not be easy to adjust the parameters and order the cuts . Its my understanding that SheetCAM will work to generate code for MyPlasma controllers but that may not be the case. Someone who has done it could possibly chime in and let us know. If you piece a the correct height for the correct times you wont burn out consumables prematurely.
