Rail Mod coming Soon!
Joe Jones
Post by Joe Jones »
Now that my 4x8 fiber laser is up and running, I have designed a modified grate section for it that will allow me to place the PlasmaCam rails beneath the laser for TWO awesome mods.
The first mod will be to slice the rail where the cam followers currently roll along that flat SOFT METAL edge of the 11 gauge sheet metal. PlasmaCam owners know that this edge mushrooms down over time, because the hardened cam follower pounds the soft edge of the rail as it rolls over plasma dust, and eventually, the rails are worthless.
So I am going to cut off that edge and replace it with a length of cold roll steel round bar. With a 3D printer, I will create a set of clips that will be attached to the rail, and allow an owner to drop a 3/16" round bar onto the rail edge in place of that flat factory edge.
The really great thing about this is, when the round bar begins to flatten out, you can simply rotate it 22.5 degree and you will have a brand new, smooth round edge for the cam followers to roll along. Rinse and repeat eight times until it is finally time to replace the round bar, which will simply snap into place.
The second mod involves the gear racks. I will laser cut small oval slots in the top of the rails, and small round holes through the gear racks. The holes will be tapped to receive a small, shallow machine screw that will pull the gear rack up against the top of the rails, rather than relying on that incredibly poorly designed "pinch" system that PlasmaCam devised. :roll:
The rails will HANG from the machine screws and you will be able to easily shift them left or right just a smidge, to get them perfectly aligned for the crossover on 510 tables. Alignment of the gear racks will be done by tightening one gear rack and using the gantry drive shaft to engage the second gear rack. Once the crossover is smooth, you will simply tighten that gear rack into position from above.
Table owners will never need to buy new rails from PlasmaCam ever again. I think I will work out an exchange system. You buy my modified rails, and after installing them, you send me your old rails which will then be converted to the round bar surface and sold to the next customer. I MAY even powder coat them, but I have not decided if I will go THAT far.
The first set will be built soon. I am still preparing to cut the new grates for the laser table which will give me six inches of additional gantry to grate clearance so I can place larger items beneath the laser.
This is exciting! Imagine the cam followers, which are round, hardened cylinders, rolling along the top of hardened round bars at a perpendicular angle! They SHOULD be smooth as silk!
The third task for this laser, is to cut a set of grates for the PlasmaCam tables that sets up a 2" square drop area, rather than the 'YUGE 6" drop area that the tables have now. It will also have a 2x2 region built into the grates that creates a 1"x1" grate for small item cutting.
Equally amazing, will be a center section that can be removed to place a large square or rectangular tube into a trough, so you can cut much larger items when needed. I think I will allow it to hang below the table frame, so you can cut longer material without the rails getting in the way.
All of the grate points will be removable and replaceable at will, as they are damaged. I will probably sell them in 100 packs, all cut on my table. :mrgreen:
So, Good things are coming! I have been gritting my teeth, waiting for this laser to arrive, so I can jump onto these projects.
DieselFumes
Re: Rail Mod coming Soon!
Post by DieselFumes »
For your first mod, why not use a hardened v-rail rather than 3/16 round bar. The v-rail will be a permanent solution, will be straighter and stronger.
In the past to "mate" up to pieces of gear rack perfectly I use short piece of rack, 1" is all you need, and lock the teeth of it into the 2 pieces of you rack you are trying to align or mate together. You get perfect spacing every time and its pretty critical to have it perfect for a smooth transition.
Tracker CNC 4x4
Joe Jones
Post by Joe Jones »
DieselFumes wrote: Sun May 18, 2025 12:47 pm For your first mod, why not use a hardened v-rail rather than 3/16 round bar. The v-rail will be a permanent solution, will be straighter and stronger.
And also more expensive. It would also require modification of the gantry to roll on V rails, where the cam followers PlasmaCam tables currently use will roll over the top quadrant of cold roll steel bar just fine.
DieselFumes wrote: Sun May 18, 2025 12:47 pmIn the past to "mate" up to pieces of gear rack perfectly I use short piece of rack, 1" is all you need, and lock the teeth of it into the 2 pieces of you rack you are trying to align or mate together. You get perfect spacing every time and its pretty critical to have it perfect for a smooth transition.
Right. But that is because the gear racks are installed by holding them UP inside of the rails as a second person tightens down the squeeze screws, and the results are If-Y. If the rails are hanging from machine screws that poke through the tops of the rails, the gear racks have a smidge of wiggle room. So we tighten one gear rack into place, and use the drive shaft and gears of the gantry to roll across the butt joint to the second rail. When the transition is smooth, due to the drive shaft gears determining the correct position of the second gear rack, it can be tightened from above, and the transition is then smooth.
The gear racks will have vertical, threaded holes that allow short machine screws to thread down into the gear racks, but the threads do not invade the path of the mating gears. The holes will be precisely positions using the 4x8 laser table.
Joe Jones
Post by Joe Jones »
The fires in La Haina and in other places recently has shown us that the powerful DEW lasers they are using to destroy humanity are powerless against the BLUE color used on roofs, and boat tarps, etc.
I didn't think this was the case, and it was only an excuse fabricated by the NWO. However, I learned that it is absolutely TRUE!
I put a PlasmaCam rail under my 1,000 Watt fiber laser to cut the flat edge off, and to cut oval holes at the top for a mod that will replace the soft, flat edge with a round cold roll steel bar, and the gear racks will mount to the TOP of the rails via small machine screws, instead of that stupid "pinch screw" system PlasmaCam uses to hold the gear racks in place. I will drill and tap vertical holes through the rails for this purpose.
Color me SURPRISED! to discover that my laser could not even TOUCH the rails that were covered by the PlasmaCam blue paint. We tried a cut for 12 gauge material. The rail just laughed. We switched to 1/4 steel settings and it barely scratched the surface. We did finally get it to cut using a setting for 1/2" steel! However, it left a horrible mess and destroyed the rail completely, and took out a $68.00 laser lens too. The edge might as well have been cut using a chainsaw, and the heat twisted the rail into a useless curved mess.
So I grabbed another rail, and used sanding disks to REMOVE the PlasmaCam blue coating, and then the laser cut the rails crisp and clean, without issue!
It is a learning lesson, for sure. I am now looking for some PlasmaCam blue roofing coating for my home and my shops, If that blue color truly fights off the DEW lasers they will use to kill us all, then I want a fighting chance!
