I've cut the 4 ft part of this as that is what my table is, but if you have an 8 ft table you may have to modify to fit your brand.
The slots are offset so you can put flat bar stock into them and it will curve.
I found it very hard to get the right offset so the space for bar stock is no too loose. You have to experiment a bit.
This is not cut ready as is.
You currently do not have access to download this file. To gain download access for DXF, SVG & other files Click Here
