Hi all. We have designed our company logo and would like for some input as to how it looks and what more may need to be done to send to our DHC2 PlasmaCam. Thanks in advance for any comments. K D Metal Werks. PlasmaCam DHC2 Hypertherm Powermax 45
Help with first creation
K D Metal Werks
PlasmaCam DHC2
Hypertherm Power Max 45
Hobart Handler 190 Mig
Niagara 3"x 36" Slip Roll 14ga
Driess/ Krumph 4' box & pan brake 16ga
Hossfeld #2 Bender Ridgid 700 threader
Pexto 137-1 16ga. Stomp Shear
MADE IN USA
PlasmaCam DHC2
MADE IN USA
Re: Help with first creation
Can't open it in Plasma Cam. Not sure why. Try exporting it as a dxf file and posting that. Thanks
Dave Hanks
Dave Hanks
Hi KD, Looks like a few pieces will fall out . Otherwise looks great. Here are some suggestions......Russ K
OK. Thanks to Russ, looks like what I am looking for. I see what he did to keep pieces from falling out but having no luck recreating his adjustment. I can not seem to figure out how to open up the D like he has. No doubt it is simple, but I guess my mind is much simpler, lol.
K D Metal Werks
PlasmaCam DHC2
MADE IN USA
PlasmaCam DHC2
MADE IN USA
K D Metal Werks
PlasmaCam DHC2
MADE IN USA
PlasmaCam DHC2
MADE IN USA
Your D, A, and R are going to fall out and just the outside outline will show up on your sign. In order to keep the insides, which will give you the actual "letter", and not just the outline, you need to keep it attached to the main part of the sign (the rectangle). The way to do that is to stencil your lettering....in Plasmacam, it is a simple as drawing two parallel lines say at the bottom middle of the A, while letting the lines run beyond the actual lettering, and then use the trim function to cut off excess and to trim out the letter itself so that you have a small strip to hold the middle to the rectangle...
Probably makes no sense to you, but I would very highly recommend that you go to the video tutorial that came with your software, and go through chapter 7 thoroughly to at least get the basic functions down pat...what you are asking is some of the simplest functions to perform, and I can promise you that you will not be able to cut much of anything until you have a command of these....not trying to be critical....just save you some time....and material...
Thanks for the info cjdauthier. I had forgotten about Chapter 7 as it is only available in PDF form. I have printed it out and placed in a binder. I take it with me when I work so I can read when time permits. When I get home, I am practicing. Making much sense now.
K D Metal Werks
PlasmaCam DHC2
MADE IN USA
PlasmaCam DHC2
MADE IN USA
